Dashboard and firewall stuff
Old Mar 19, 2000 | 04:57 PM
SteveS's Avatar
SteveS
How do you get the **** off the light switch on a '69? The wipers had an allenhead set screw but there is no sign of one on the lightswitch ****.
Is there a good source for the grommets and seals used where wiring,cables,steering column,etc.. penetrate the firewall? Maybe somebody offers a complete kit? I am gutting the interior prior to removal of the cab for stripping and painting and the old seals pretty much fall apart when you mess with them.
The saga of the restoraton of Grandpa's truck continues. Thanks for any help.
Steve
'69 F100
Old Mar 19, 2000 | 05:43 PM
Nathan's Avatar
Nathan
To remove the headlight switch shaft (**** attached) reach behind the dash to find a small button on the switch body. push in this button and pull out the shaft. As for the grommets, your local hardware store should have some that will work.
Nathan
Old Mar 19, 2000 | 06:36 PM
jowilker's Avatar
jowilker
Steve the **** has a V clip at the back set at an angle / on the shaft. Use something to push it towards the **** and the **** should come off.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 19, 2000 | 08:24 PM
CBs63's Avatar
CBs63
Steve check Mac's Antique Auto Parts 1-800-777-0948 or check www.macsautoparts.com . I know they have the steering column seal for 67-72.
CB
Old Mar 19, 2000 | 08:25 PM
SteveS's Avatar
SteveS
Thanks. Its off. Thank God these trucks are simple; I'd hate to be doing this on something complex.
Steve
'69 F100
Old Mar 20, 2000 | 01:05 PM
Chuck71's Avatar
Chuck71
Steve - just curious - was it the button or the v-clip that was holding the **** on?
Chuck
Old Mar 20, 2000 | 04:28 PM
SteveS's Avatar
SteveS
Chuck,
It was the button on this application.
Steve
'69 F100
Old Mar 21, 2000 | 11:55 PM
Thudpucker's Avatar
Thudpucker
The V-clip is on the Windshield wiper ****.
Old Mar 21, 2000 | 11:59 PM
mk's Avatar
mk
....on the 73-79's.
Old Mar 22, 2000 | 12:40 AM
mk's Avatar
mk
steve340
Sep 3, 2014 07:01 PM
goin-lo-coe
Oct 26, 2013 01:50 PM
Steve2916
16
Jan 6, 2011 10:34 AM
Blue65
Jul 13, 2001 02:58 PM
stephenw
17
Feb 15, 2001 10:17 PM
