390 engine rebuild-step 1
Old Feb 27, 2000 | 01:34 PM
73350's Avatar
73350
Given a choice of three longblocks 1) 1962-64? 390 4-V from a thunderbird or 2) 1968 F-250 360 2-V or 3) 1973 F-350 360, 2-V What block(or interchanges) should I use for my 390 build up project? My budget is around $700.00 for performance parts. The motor will go into a 1968 F250, auto(built for pulling a trailer & trying to maintain good mpg). Thanks for the details.
Old Feb 27, 2000 | 03:05 PM
Trail_Rider's Avatar
Trail_Rider
So long as the blocks are sound any of them should work, if you want to wind up with a 390 and you've already got one to start with.... If the 390 block is bad use the internals on one of the 360 blocks, and voila!
Trail Rider
Old Feb 27, 2000 | 03:57 PM
StockMan's Avatar
StockMan
I believe that the pre-65 FE blocks used a different bolt pattern to bolt the motor mounts on. I do not see any advantage to using that block over the others all other things being equal. Pick the block which has the best bores (least taper, least out-of round and smallest overall diameter). The less machining you have to do the cheaper your project. $700 is not exactly a killer budget, but with the right choices and elbow grease, you will have one fine motor indeed.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Feb 27, 2000 | 04:35 PM
73350's Avatar
73350
I should have been more clear. My total budget for the rebuild is around $2500.00. I figured I would spend $700.00 on upgrades such as cam,intake,etc.. I hope that clears things up.
Old Feb 27, 2000 | 06:13 PM
Nathan's Avatar
Nathan
You might check some #s on that 62-64 390 motor and see if you are lucky enough to have a HiPo. If I remember correctly, a 62 390 HiPo with a 4bbl is worth about 390 horsepower, and with 3-2bbls, is 410 horsepower in stock form. If you have one of these, you are a lucky dog indeed.
Nathan
Old Feb 27, 2000 | 06:52 PM
BigBrownTruck's Avatar
BigBrownTruck
Check your heads for casting numbers (perhaps without the 6090) Look between the middle spark plugs.
COAE 6090 D 60 352HP, 61-62HP, early 62 390HP w/dished pistons
C2SE 6090 A 62-63 T-bird 390 6V, late 62 390HP w/ flat top piston.
C4SE 6090 A same as above
These heads have smaller combustion chambers and bigger intake ports than ordinary FE heads.
BBT
Old Feb 27, 2000 | 07:16 PM
jowilker's Avatar
jowilker
73, I believe that the cam, carb, and intake (Edlebrock) was about $800.00 The MSD coil, dist. & wires was $325.00 for my 352 so choose carefully.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 1, 2000 | 09:53 PM
FE427TP's Avatar
FE427TP
one other thing to consider is the 390 rods are a lot stronger than the 360 connecting rods, and with ARP bolts you shouldn't have any problems
Old Mar 2, 2000 | 12:04 AM
390GT's Avatar
390GT
my advise with a 390 is to keep it to a pulling truck is that you shouldn't have to do anything special..just find the strongest block.
use a low rise 2bbl intake and maybe shave the heads....if you do have hypo heads i wouldn't use them for pulling purposes...
keep the hypo heads for a 390 car application
Old Mar 22, 2000 | 06:36 PM
nathanael's Avatar
nathanael
good mpg with a 390, ha ha ha.
Old Mar 23, 2000 | 01:06 AM
Ford390's Avatar
Ford390
My only advice would be, go four barrel if you can afford it. I will as soon as I can find a 4 barrel intake. Also, whether you go 4 barrel or not, definitely check around with local buddies and shops and have the best carb you have access to rebuilt by somebody that really knows what the hell they are doing. It's amazing how well these guys can rebuild carbs. For $200 I simply turn the key once and never have any problems starting. It's well worth it, believe me.
Old Mar 23, 2000 | 08:58 PM
ole65's Avatar
ole65
Didn't some of those high performance heads run up the compression ratio to something like 10.5:1? Personally, I wouldn't want to start with anything more than 9.0:1 for an everyday driver. Just a thought.
Lee
1965 F100 short box styleside
Old Mar 23, 2000 | 09:31 PM
390GT's Avatar
390GT
they did run 10.5/1 but that was when they were produced and on leaded fuel..it'l drop now...
if youre looking for a 4bbl intake i have one..a cast iron one.....i have no use for it...
Old Mar 23, 2000 | 11:58 PM
mocky's Avatar
mocky
F250fordtruck
Aug 18, 2015 09:21 PM
srsbjohnson
Aug 6, 2013 04:28 PM
dferg250
Sep 27, 2012 05:14 PM
kgh
Large Truck
Apr 1, 2012 11:01 PM
Big Skier
18
Mar 31, 2008 08:07 PM
