HHEEELLLPPPP
Old Dec 26, 2009 | 05:53 PM
Daniel428's Avatar
Daniel428
Exclamation HHEEELLLPPPP
I have been trying to figure out why my fuel pump isn't getting any power.
I have replaced the pump, filter, relays and fuses.
Today I found that the fuse box inside the cab isn't getting power to some of the fuses including the main fuse.
Any ideas?
Thought maybe the ignition control module or switch because truck was running fine until I came out of taco bell, tried to start her and the fuel pump wouldn't kick on.
Old Dec 26, 2009 | 06:00 PM
dustybumpers's Avatar
dustybumpers
check the fuseable links hooked onto the solinoid. what truck? what engine? what year?
Old Dec 26, 2009 | 06:22 PM
Daniel428's Avatar
Daniel428
Exclamation
1996 Ford F150 4WD 5.0 302.
I no by the solenoid but what are and where are the fusible links??
Old Dec 26, 2009 | 07:48 PM
dustybumpers
solinoid is the round thing on the passenger fender that hooks to the battery. there are some small wires comeing off where the battery cable hooks up. these are the fuseable links. basically a wire disigned to burn out just like a fuse
Old Dec 26, 2009 | 09:22 PM
Daniel428's Avatar
Daniel428
Exclamation
Okay so is there an easy way to find out if the wire is fried?
Thanks again
Old Dec 27, 2009 | 06:22 AM
jplinville's Avatar
jplinville
Thanks again
Check the continuity.
Old Dec 27, 2009 | 06:59 AM
subford's Avatar
subford
Does your radio work OK, if so the fuseable links are OK.
If the radio works more than likely you have a bad Ignition switch.
I take it fuse number 22 is one of the fuses not getting power.
Old Dec 27, 2009 | 03:24 PM
Daniel428's Avatar
Daniel428
Exclamation
I thought the ignitioh switch, is that a shop job?
Im not sure what to do for that.
