Modular V10 (6.8l)
o/d off light blinking
Old Dec 26, 2009 | 03:10 PM
green250's Avatar
green250
I just installed a 2002 v10 and ecm in my 2000 f250 super duty and for some reason the o/d off light is blinking.Ive done some searches and come up with a few ideas but id like more input from you guys.Its got a 6 inch fabtech lift kit and 35 inch super swampers on it.Im running 4.56 gears fron and back.The truck shifts fine and the button works to shut off o/d and im reading no codes from the ecm.could it be the gears and the tires are making it blink?I saw one post where someone said it would.Also the torque converter has a lower than stock stall.I would think if the wires inside the shifter were bad or broken than the button wouldnt work but it does.also the fact that it is not throwing any codes has me confused.There is no harsh shifting at all and it goes through all gears.Fluid levels are normal and operating temp is normal.Im getting a 5 star tuner as soon as mike gets back from the holiday break and recieves my order.Im hoping it will cure the blinking light.Any ideas or opinions are totally welcome!Thanks.
Old Dec 26, 2009 | 05:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is throwing a code. You just don't have the right tool to read it.
Old Dec 26, 2009 | 06:49 PM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Hi green250
I emailed you just now, give us a call anytime tomorrow and or Monday to firm up things...
Mark is right a blinking light is a code. Need to read that code...
Old Dec 26, 2009 | 10:38 PM
green250's Avatar
green250
ok got the code read and its a p1729 4x4L code.Dont know what it means but i hope its just a bad sensor.
Old Dec 28, 2009 | 03:49 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It could be that the 2002 doesn't use the GEM module, like the 2000 does, for the 4x4 control.
Is the truck ESOF, or the truck the new PCM came out of ESOF?
Old Dec 28, 2009 | 03:50 PM
krewat's Avatar
krewat
Hey, you know, you should be able to use the 2000 ECM for the 2002 engine, it's not a major difference.
Old Dec 28, 2009 | 09:49 PM
green250's Avatar
green250
thanks for the replys guys.I talked to mike and we figured out the code was caused by the 2002 computer coming from a 2x4 truck.He said its just a matter of turning it on in the ecm with the program he is sending me for the 5 star tuner.
Tmurphy38
Nov 13, 2016 08:35 PM
tmathers03
1983 - 2012 Ranger & B-Series
23
Nov 6, 2016 06:56 AM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
TX92F150
Aug 8, 2013 08:32 PM
SLE
Modular V10 (6.8l)
27
Jul 15, 2011 06:47 AM
