Injector Removal ??
Old Dec 26, 2009 | 01:39 PM
Izzy351's Avatar
Izzy351
What I did was after putting in all the injectors, I pulled the glow plugs and put the VCs back on. with a couple bolts to hold them down. I then cranked the engine a few times with the wiring harnesses disconnected a couple times. That clears the cylinders and pushes all the liquid out. Of course, it washes down the oil passages to the pan. I then drained the oil pan and poured a half a quart of clean oil down the top of each of the heads to flush things out. Top off with fresh oil and be ready to crank a bit before the HPOP builds enough pressure to fire the injectors.
Old Dec 26, 2009 | 06:53 PM
RussB's Avatar
RussB
well I got the injector pulled at reinstalled ! Thanks for a help everyone here and John (fordzilla) who came over and lent a hand for a couple hrs. HOWEVER ! This all did not solve the problem... I've got tons of fuel in my coolant overflow bottle and it still runs like s^%$ ! This motor is getting pulled and sent back for refund ASAP.
Old Dec 26, 2009 | 07:54 PM
medhvac's Avatar
medhvac
not good ,not good
gov2mod
46
Feb 17, 2019 01:26 AM
8 lug nut
Sep 13, 2014 04:35 PM
Xenthrax
21
May 16, 2013 02:41 PM
neversosure
General Diesel Discussion
48
May 24, 2011 06:29 AM
doorstop
Oct 25, 2010 11:16 AM
