Lower Front Shock Mount (Pics)
Old Jan 1, 2010 | 02:35 PM
starmilt's Avatar
starmilt
Originally Posted by S.P.
Well it could be that the PO had the front spring sag problem and bent/broke then welded it.
Man thats really scrape'n for an answer, but its the best I could come up with.
Goofy but what I was thinking too.lol
Old Jan 1, 2010 | 02:44 PM
mechelement's Avatar
mechelement
My front springs are definitely sagged. Maybe 1-1/2" between the bump stop and flat tab on that mount. The spring and shackle bushings look rough.
Old Jan 1, 2010 | 05:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The springs are probably not sagging, the mounting bolts and bushings are worn out.
I wasted 300 dollars on new springs only to find out that front spring shackles and mounting bolts were the only thing that changed the ride height, the springs did nothing.
Getting the bolts out were a real pain, so I swapped in the new mounting hardware as I got the old ones apart, the swapped the springs after all the new mounting hardware was swapped in.
New hardware increased the ride height about an inch.
New springs and it was still sitting at that one inch increase.
I had about 300K on mine when I swapped springs.
Dana 60 and a third spring leaf, 3" more.
Old Jan 1, 2010 | 05:37 PM
mechelement
Should I just get an Energy Suspension kit for the whole front end on this truck? I'd rather go that route before taking the front leaf springs in for a re-arch or getting new ones. This is on a D50 TTB front axle. I might as well do the rear end too.
Did you install new shackles too?
mechelement
124
Nov 1, 2023 03:38 PM
optikal illushun
49
Jul 25, 2023 11:20 AM
fiftyfordfloored
Feb 14, 2022 08:48 PM
fiftyfordfloored
'80-'86 FAQs (Frequently Asked Questions)
Aug 3, 2014 06:32 PM
mechelement
74
Jun 15, 2010 04:58 PM
