cold weather oil weight?
Here in Mn we get a lot of cold weather. I always run full synthetic since its a better oil and doesn't change the thickness as much when it gets cold. I run 5W-30 in my 75 truck with a 429 but its a newer build with great oil pressure. Never goes below 40 psi. My 92 f150 with a 302 I tried 5w-30 but the oil pressure was lower than I liked. It has 138,000 miles on it. I would recomend running 10W-30 or 10w-40 full synthetic for a 400 with lots of miles. That is what I would run in MN.
I ran 20w50 year round in my old cougar with a 302, but it had issues with lightweight oils. Oil pressure with a 5w30 would drop to 25 to 30 pounds, 20w50 was always 50psi. So there is no correct answer its all about your engine and what it needs. If you don't have a proper oil pressure gauge to monitor the changes just stick with a 10w30, and as someone said above synthetics don't get as gummy when cold or as runny when hot.
P.S. Castrol synthetic is on sale at O'Reillys right now.
At those temperatures it is not to going to make a lot of difference.
Each engine is different and the more wear your engine has the more need for thicker oil. Multi-viscosity oils handle this very well.
Do not use an oil with low zinc content in a flat tappet engine or you will risk ruining the cam.
clunker86
01-19-2007 10:09 AM
to many oft
13
12-13-2005 06:02 PM
dburgess
02-05-2003 06:47 PM
