f250 weight
Old Jan 16, 2007 | 07:25 PM
clunker86's Avatar
clunker86
f250 weight
i need to know how much weight a 1986 f250 with a 400 c6 4x4 weighs in at. i am going to look at a toe bar tomorrow, for when i flat tow her to ohio from va. thanks
Old Jan 16, 2007 | 07:40 PM
Franklin2's Avatar
Franklin2
I believe it's on a tag on the door jamb. If I am thinking right, you can subtract 3/4 ton(1500 lbs) from the GVW number, and be close to the weight of the truck. You may also be able to look at the title.
Old Jan 16, 2007 | 09:57 PM
ruppertsf250's Avatar
ruppertsf250
My truck, an 86 F250 supercab longbed 2 wheel drive weighs about 6000 lbs. Has a 460 and a C6. I think my tag read 5999 lbs for weight and 8800 for gvw. Its just over 6000 with some junk and passengers, had it weighed when going to the dump a while back.
Old Jan 17, 2007 | 11:41 PM
5.0Torx's Avatar
5.0Torx
how much would my barebones, standard cab, long bed, 19 gallon fuel tanked, 4x2, 300, np435 1983 F-250 weigh in at, roughly?
Old Jan 18, 2007 | 12:03 AM
82F1507.5's Avatar
82F1507.5
Again, that information is on the door jamb. It is listed as weight, GVW is Gross Vehicle Weight or towing capacity.
Old Jan 18, 2007 | 10:33 PM
laneyboy6933's Avatar
laneyboy6933
it's probly going to way between 6500 to maybe 8000 pounds. My 84 f250 4by4, longbed, with the 460 weighs around 10500 i believe.
Old Jan 19, 2007 | 06:11 AM
Duncan10's Avatar
Duncan10
Last edited by Duncan10; Jan 19, 2007 at 06:13 AM. Reason: didnt want to upset people
Old Jan 19, 2007 | 09:35 AM
aj197816134's Avatar
aj197816134
10,500 may be the GVW Gross Vehicle Weight. That means max capacity to haul, tow etc.
Check the door Jamb, alot of infomation on that sticker.
Old Jan 19, 2007 | 10:09 AM
84-250's Avatar
84-250
The truck in my sig weighs just under 4000lbs with a near empty tank and me (140lbs). The gvwr is 7300lbs
Reallyoldnavy
Oct 19, 2013 12:45 PM
moose77792
Feb 13, 2012 03:28 AM
TexasA&M
Jul 18, 2011 02:41 PM
Chris89lx
All Things Towing
18
Mar 27, 2009 04:12 PM
crescentwrencher
Mar 17, 2008 12:57 PM
