"Script that's running.."
Old Dec 23, 2009 | 04:56 PM
ford2go's Avatar
ford2go
Every now and again I get a pop up that says something about a 'Script that's running is slowing down your computer -- would you like to stop it'.
Has just started in the last few days (and I've run NAV and spybot since it started)
Doesn't matter what I do, I either have to kill FTE, or it will stop responding, and then I have to kill it.
Has yes and no buttons plus a little x for closing it, but nothing makes any difference.
Only happens on FTE as far as I can tell.
I didn't make out a ticket on this because it happens so intermittently. Just thought that I'd mention it.
Old Dec 23, 2009 | 05:43 PM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
What browser are you using and is it 100% up to date? I am running the latest FF and get it every once in a while on a forum site. I belong to several and it isn't always FTE. Not sure why but once I stop it and re-load the browser and page everything runs fine.
It may also be a function of what else is going on. If I have too many windows open, the script hangs up trying to execute.
Old Dec 24, 2009 | 12:19 AM
ford2go's Avatar
ford2go
I'm using IE7 (NOT 8). I usually run 2 or 3 windows, but I've cut it down to one and I still get the problem. I've had it happen repeatedly even after I closed down and cleared everything.
I go to a couple of other forums, and I don't see it there -- although they're much smaller than FTE
Old Dec 24, 2009 | 03:36 PM
*2fords*'s Avatar
*2fords*
I got that message the other day, just as i was leaving FTE, I just closed it and all was fine after.. it hasnn't been back since.
Old Dec 24, 2009 | 03:38 PM
andym's Avatar
andym
It sounds a little suspicious to me. Are your virus scanners and spyware scanners up to date with the latest signatures?
dchamberlain
Mar 29, 2010 04:07 PM
cjben
34
Jun 19, 2008 08:07 PM
tdister
28
Apr 14, 2007 01:34 AM
