Vacuum pump pulley
Old Dec 23, 2009 | 11:35 AM
jedstamm's Avatar
jedstamm
Vacuum pump pulley
Does anyone know where I can get a vacuum pump pulley for a 7.3 in an 89' model? I've searched all over Ebay and the net. I can easily find a new vacuum pump, but I haven't had any luck finding a pulley. I realize a salvage yard is probably the best bet, but unfortunately I'm 100 miles or so from the closest salvage yard.
Old Dec 23, 2009 | 11:44 AM
Links56's Avatar
Links56
What happened to yours? I would say a Junk Yard is your best bet.
starmilt's Avatar
starmilt
Does the 89 have the v belts or serpentine pulleys. Where are you located.
Old Dec 23, 2009 | 12:33 PM
jedstamm's Avatar
jedstamm
It has the v belt that runs off of the front groove from the alternator pulley. Mine I messed up when I was removing it from the old vacuum pump. I could probably salvage it, but I'm afraid I'll never get it true which will more than likely knock the bearing out of the new vacuum pump.
Old Dec 23, 2009 | 01:11 PM
starmilt's Avatar
starmilt
Where are you.
Old Dec 23, 2009 | 03:42 PM
jedstamm's Avatar
jedstamm
SW Nebraska. I just ordered one from the local ford garage. It cost 53 bucks, but that's cheaper than having to drive a couple hundred miles to pick one up at a salvage yard.
Old Dec 23, 2009 | 04:22 PM
starmilt's Avatar
starmilt
Ok I am pretty sure I have one but you are a little far off but if you can wait on the mail and can cancel that order I will look.
Old Dec 24, 2009 | 07:07 AM
rckslash2010's Avatar
rckslash2010
I had the same problem with mine. Why can't they make it a little easier on a guy and have a pulley already installed on the pump? Just to save them 5 bucks. Heated mine up and got it as strait as I could, I don't think it will screw the bearings up all the fast, but I've been wrong many times before.
Old Dec 24, 2009 | 09:49 AM
jedstamm's Avatar
jedstamm
I saw they make a tool to remove the pulley, but it costs as much as a new pulley from Ford. Thanks for the help everyone.
Old Dec 24, 2009 | 10:34 AM
starmilt's Avatar
starmilt
It is a power steering pump pulley remover. Most parts houses will pull it for free if you are dealing with them.
Old Dec 24, 2009 | 11:34 AM
jedstamm's Avatar
jedstamm
Here's the link. It specifically states it's a vacuum pump pulley remover for new and older Ford diesels. 7922 OTC Tools & Equipment Ford Diesel Vacuum Pump Pulley Remover Jaws
Price $67.46
Product Code: OTC7922 Qty:
Description
Ford Diesel Vacuum Pump Pulley Remover Jaws These jaws, together with No. 7185 pulley remover, make quick work of vacuum pump removal on newer Ford diesel engines.
Product Features
• For use on 1984 to ’87 6.9L, and 1988–2003 7.3L.
• No. 7922 – Ford diesel vacuum pump pulley remover jaws.
Old Dec 24, 2009 | 11:44 AM
starmilt's Avatar
starmilt
Yea no more often than you need one it is cheaper to just let the parts house do it for you.
Passin Thru
Sep 24, 2011 03:14 PM
SumoPigeons
15
May 20, 2009 09:42 AM
flagator
Dec 7, 2004 04:54 AM
mikescamping
Jul 8, 2000 08:51 AM
