Vacuum pump pulley
Old Sep 24, 2011 | 01:15 PM
Passin Thru's Avatar
Passin Thru
Vacuum pump pulley
Does the vacuum pump pulley have a lock ring or is it just pressed on? Mine took adump and I bought a NAPA replacement only to find it did'nt have a pulley. Thanks
Old Sep 24, 2011 | 01:28 PM
chicagodragon's Avatar
chicagodragon
pressed. use a power steering pump pully tool. most stores have one
Old Sep 24, 2011 | 01:32 PM
Action4478's Avatar
Action4478
Puller / installer pic...Name:  Pully puller tools.jpg
Old Sep 24, 2011 | 01:39 PM
Passin Thru
Thanks. Worried it had a lock ring and would bust. PT
Old Sep 24, 2011 | 01:42 PM
DDPJ's Avatar
DDPJ
I had to replace my pump, the replacement came with the pulley already on. Year of vehicle perhaps?
Old Sep 24, 2011 | 01:55 PM
paddler's Avatar
paddler
Bolts First, then pulley
When installing... at least put the bolts in the pump holes first, before installing the pulley. At least one of the bolts won't go on with the pulley in place. You can mount the pump then install pulley (easiest), or put the bolts in the pump holes, then mount pulley, then mount pump. Pulley first will cause you to cuss then take the pulley off.
Old Sep 24, 2011 | 03:14 PM
Passin Thru
OK, thanks. Saw that bolt problem. I've been thru a lot of cusssing as I worked on airplanes and some of those are stupidly designed. One is a Cessna 210. The oil filter is nearly impossible to remove. Thanks
RenoHuskerDu
Jul 17, 2018 11:02 AM
kyle j
Aug 5, 2012 11:37 PM
Jaaaaaaackman
Mar 10, 2012 08:53 PM
GHeTTo JOe
13
Oct 8, 2011 09:24 PM
Slopetruck
Jan 4, 2008 06:17 PM
