electrical problems
Old Dec 23, 2009 | 10:41 AM
FEman72's Avatar
FEman72
electrical problems
So I went out to start the truck the other day. It's a 72 F250. And I got nothing out of the ignition. Not even a click. Then I went and tested the battery, and it showed over 13 volts so it's charged. Then the headlights didn't work either. I replaced the solenoid a month ago. I'm also re doing the brakes right now but nothing changed after I got everything put back together. Where would the problem be? I'm kind of new to this.
Thanks in advance.
Old Dec 23, 2009 | 04:51 PM
gearloose1's Avatar
gearloose1
If there is no click.. is the solenoid powered?
If yes... then see if the starter is frozen.
Old Dec 23, 2009 | 05:40 PM
Franklin2's Avatar
Franklin2
Turn the headlights on, and then re-check the voltage at the battery, and the voltage at the starter solenoid bat + connection. If that's all good, leave the headlights on and check for voltage in the fuse box for something like the brakes or the horn(something that is hot all the time). Keeping the headlights on will keep a load on the circuit and give you a true reading.
RacinNdrummin
2196
Oct 20, 2018 05:56 PM
jayRmichigan
Oct 11, 2013 12:24 PM
DixieLynn72
Apr 13, 2012 06:57 AM
bvwarrior
15
Dec 23, 2002 09:16 AM
proeliator
Electrical Systems/Wiring
29
Nov 27, 2002 12:26 PM
