460 compression ratio for 87 octane?
Old Dec 22, 2009 | 08:02 PM
mort2000's Avatar
mort2000
i'm rebuIlding the 460 in my 84 ford, I got the cobra jet timing set to advance the cam, hedman log tube headders, and edelbrock performer intake, and a decent rv cam. im just trying to figure out what CR i should go with. i dont want to run premium fuel because it drinks it way to fast! So what would be a good number to shoot for? any help would be great!! thanks
justin
Old Dec 22, 2009 | 09:12 PM
nordvik72's Avatar
nordvik72
With everything you named off it wont change your compression ratio at all. If you were to upgrade your cylinder heads and maybe they had a different size combustion chamber then it would go up and the same thing when changing piston head type's. You can google compression ratio calculator and it will give you directions on what different things will change compression ratios. The thickness of a head gasket will also help pin pointing a exact ratio But to answer your question you wouldnt want to go above 7 or 8 if you want to stick with 87 octane.
Old Dec 23, 2009 | 12:35 AM
mort2000's Avatar
mort2000
Im sorry, i guess i should of said i was trying to figure out the CR because im getting ready to order the pistons. my bad....
Old Dec 23, 2009 | 08:58 AM
OldRacerGuy's Avatar
OldRacerGuy
I'd shoot for 8.0-1 to 8.4-1 or so. I've read that you can run higher compression if you get the quench good and tight by decking the block or running a taller piston with more dish instead of using a shallow dish set deeper in the bore.
Old Dec 23, 2009 | 12:12 PM
Bear 45/70's Avatar
Bear 45/70
In reality an 8.4 to 1 is way low for using 87 octane for optimum power. A 9.0 to 1 is closer to what you want and will up the power output some over stock. Do not go over 9.5 to 1 if you want to continue to use 87 octane.
Old Dec 23, 2009 | 01:38 PM
nordvik72's Avatar
nordvik72
That may be pushing for detonation with 87 octane, whats the stock Compression ratio? I wonder what the owners maual says for type of gas to use. Anyway yeah decking the block will also up the compression a bit.
Old Apr 5, 2013 | 04:08 PM
TrippingCobras's Avatar
TrippingCobras
I would tend to agree with this. If you are running 8.0 to 8.5, there had better be a forced induction system to go on top of it. The duration of the cam has a lot to due with the recommended compression, usually the longer the duration, the higher the compression that is recommended by the cam manufacturer. The higher compression requires higher octane, but that is only really a problem when you are on the throttle. Your timing is usually the culprit for "pinging".
I haven't done the research, but I have heard people state that aluminum heads are not as prone to pre-ignition as cast iron.
I am about ready to build another 460, I'm shooting for around 9.5, I've heard of people getting away with much higher than that.
Old Apr 6, 2013 | 09:32 AM
mark a.'s Avatar
mark a.
It isn't much more per gallon for 89. When you add it up, say it's .06 more per gallon thats still less than one dollar per 15 gallons. Looks very affordable when you do the math. That 87 stuff is JUNK.
Old Apr 6, 2013 | 10:33 AM
bigdan1979f-250's Avatar
bigdan1979f-250
My rebuilt 460 has 9.5:1 compression and I have no problem running 89 octane. I know its not 87 octane, but like Mark said, it really isn't that much of a price difference. Not sure where you are from, but here in Missouri at Casey's General store (where I buy gas), the price is the same.
Old Apr 8, 2013 | 06:25 AM
DIYiT's Avatar
DIYiT
In some areas (here in Iowa), 89 octane is E10 blend. 87 got 1-2 mpg better than 89 E10, but 87 is also usually $0.10/gallon higher priced than 89.
Old Apr 14, 2013 | 07:25 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Where are you at? what elevation? What are you doing with it? If you are higher in elevation you need more compression. I run 85 pump gas in iron headed 10:1 and higher engines with NO problems. I am at 6000 ft in elevation too.
If you are going to tow much though, don't shoot much over 9.0:1 due to the heat and all.
Run a cool thermostat helps as well, I run a 160 and I went to a 195 for this last winter and definetely hurt my 10:1 460 on 85 octane. It was not as happy.
96f350rcsrw460zf
59
Sep 12, 2018 10:48 AM
BigCountry1978
Jun 16, 2016 02:44 AM
BBpwer
Mar 30, 2015 10:06 PM
jade79
26
Jun 12, 2008 06:25 PM
theguy_88
Feb 23, 2006 12:06 PM
