FE Spec Sheets
Old Apr 2, 2000 | 02:27 PM
BinderBoy's Avatar
BinderBoy
FE Spec Sheets
Old Apr 3, 2000 | 11:06 PM
jarhed420's Avatar
jarhed420
FE Spec Sheets
Hey, Does any one know where I can get spec sheets for FE engines including the musterious 410 and the 391???
Old Apr 4, 2000 | 11:17 PM
390GT's Avatar
390GT
FE Spec Sheets
i have info on FE ..not so much on the 410..its a 390 with a 428 crank....
391 is a grain truck engine.
Old Apr 4, 2000 | 11:35 PM
jarhed420's Avatar
jarhed420
FE Spec Sheets
Hey, would you e-mail me those sheets please. Thanx
jarhed420@hotmail.
Old Apr 5, 2000 | 08:43 AM
FTE Ken's Avatar
FTE Ken
FE Spec Sheets
The How to Rebuild Your Big Block Ford by Steve Christ.
Ken Payne
Ford Truck Enthusiasts Admin
[img src="/clipart/logosmall.gif"]
Old Apr 5, 2000 | 05:14 PM
tazfords's Avatar
tazfords
FE Spec Sheets
Hi Ken, I got that book, and I think it is possibly the best FE book out there. I highly recommend it as well. Got mine at Pep Boys.
Vic
Old Apr 5, 2000 | 09:12 PM
390GT's Avatar
390GT
FE Spec Sheets
for an FE block book i dont think a 391 will be in that...its likely an industrial block..actually come to think of it i have big book on industrial crap.....so if you need to know about the 361, 370, or 391 i can provide that.
Old Apr 5, 2000 | 09:26 PM
jarhed420's Avatar
jarhed420
FE Spec Sheets
Hey 390GT that'd be great if you could send me some info. I'd really appriciate it. My e-mail is jarhed420(No Email Addresses In Posts!)
Old Apr 5, 2000 | 09:50 PM
tazfords's Avatar
tazfords
FE Spec Sheets
Check it, it's there.Maybe not as much detail as the 390-428 but it does have the specs.
Old Apr 5, 2000 | 10:27 PM
BigBrownTruck's Avatar
BigBrownTruck
FE Spec Sheets
391 is an FT motor. The Steve Christ book has info on both the 391 and 410. The 410 was a 428 crank in a 390 block. The 428(410) crank is externally balanced. The book also discusses FE/FT differences.
BBT
Old Apr 5, 2000 | 10:43 PM
jarhed420's Avatar
jarhed420
FE Spec Sheets
What connectin rods will work, the 390 or the 428. For all I know they may be the same. Which head has the smallest c.c. ? I want high compression.
Old Apr 5, 2000 | 10:56 PM
390GT's Avatar
390GT
FE Spec Sheets
i'm pretty sure its 390 rods with different pistons.....if your plannin on building one i suggest not...its actually a bit of a run around...seeings how the 390 is internally and the 428 is externally....see if you can get an offset grind on your 390 crank...btw i'm building a couple of 390's so i have pistons...if you want something
Old Apr 5, 2000 | 10:58 PM
390GT's Avatar
390GT
FE Spec Sheets
if youre on icq find me at # 9251613
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
