6.9 diesel
Old Dec 25, 2009 | 04:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Forgot, but I will go up and check now.
5.25"
Old Dec 25, 2009 | 05:11 PM
onetrip's Avatar
onetrip
ok thanks alot
Old Dec 25, 2009 | 05:23 PM
onetrip's Avatar
onetrip
hello i found the airaid for a dodge 5.2 318 but its 5.125 in dia
Old Dec 25, 2009 | 06:01 PM
Dave Sponaugle
There are several guys here that have hooked ram air up to the intake snorkel on the stock air cleaner housing with good results.
I am assuming you are looking at something like this,
Airaid Intake Systems - SummitRacing.com
With that filter setup, you won't gain anything over the stock filter housing with the intake tube pulled off the intake.
Hot air from inside the engine bay is not going to help any.
I ran that intake I posted above hooked to the stock air cleaner housing before I had a turbo/turbo air cleaner housing, just eliminated the plastic tube down to the small original intake opening.
This picture was after the turbo install, but notice the stock black plastic air tube connecting the air cleaner box to the intake elbow.
Old Dec 25, 2009 | 06:04 PM
onetrip's Avatar
onetrip
ok thanks alot
Old Dec 30, 2009 | 09:46 PM
magusjinx's Avatar
magusjinx
I have been pondering the intake question also ... My idea is to make a few adapter rings so that I can stack 3 air filters on top of each other and have this stick thru a hole in the hood ... Maybe cover the hole with a scoop ...
Old Dec 30, 2009 | 09:48 PM
starmilt's Avatar
starmilt
Water is death to diesels.
Old Dec 31, 2009 | 05:12 AM
Dave Sponaugle
I don't really like any intake that has a path straight down into the engine.
Water runs downhill under it's own power.
On a 6.9 you are taking 52.5 cubic inches and squeezing it down into 2 cubic inches on the compression stroke.
2.5 cubic inches of fluid in a cylinder means it will hydrolock and severe engine damage may be the end result.
Old Dec 31, 2009 | 06:31 PM
87crewdually's Avatar
87crewdually
I wish I saved the rods out of the last Detroit I had apart. It inhaled water and end result were 2 severely bent rods and 2 blown out lower cylinder walls. Good thing it's wet sleeved. 2 piston sets and liners and it's still running.
sams6.9
Jul 6, 2017 10:18 PM
puddle
May 15, 2017 08:06 PM
SVandal
WTB - Parts & other
May 3, 2017 11:48 PM
georgeent
Air Intakes, Air Filters & Ram Air
Sep 26, 2007 03:25 PM
Bioford
Jan 24, 2007 05:34 AM
