6.9 diesel
Old Dec 22, 2009 | 07:19 PM
onetrip's Avatar
onetrip
6.9 diesel
hello does any one make a cold air intake for the 6.9 non turbo or an open air cleaner for these motors thanks
Old Dec 22, 2009 | 07:36 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
no they don't sadly.
we have to fab our own.
which basically consists of running a duct down beside the headlight,and or beside the radiator(year dependent).a K&N filter(debatable as to if the extra air flow to extra debris let into the engine is worth it-i'm going to run one,already installed.) with this,and removal of the soup bowl(if applicable)also helps increase air flow into the engine.
Old Dec 22, 2009 | 07:47 PM
starmilt's Avatar
starmilt
Onetrip sounds like a chevy handle, you should get many trips out of your 6.9 lol
Sorry I just couldn't help it. Does your truck still have the cold air intake if not you need to find one and hook it back up or many members here have built or modified theres, one has even run twin inlets.
You don't want an open air cleaner you need the air as cool as you can get it.
Old Dec 22, 2009 | 08:00 PM
9473's Avatar
9473
Not sure if this is what you're looking for.
Hypermax - Product Display
Also check..Ziggster's page for what he did with his.
Old Dec 22, 2009 | 08:43 PM
kenpobuck's Avatar
kenpobuck
Wish I had a digital camera so I could post some pics of the homemade cowl inlet I made. I noticed a little more power and about 1-2 mpg with it. I plan to mod it this spring and try to open it up some more. I wonder if it would add any boost if I closed the outside vent to the cab? I know that it pushes alot of air in the cab at 60mph and if it wasn't coming in there would it help with power?
Old Dec 22, 2009 | 09:20 PM
starmilt's Avatar
starmilt
The air vent could help but it wouldn't be noticable by itself.
Anything that causes air turbulence robs power. That is the reason race cars have the ground effects an inch off the ground. There are many things a guy can do to keep 1/10 of a horsepower freed up but if you dont do 10 of them you will not realise even 1 horsepower.
Old Dec 22, 2009 | 10:03 PM
Fishin76's Avatar
Fishin76
Someone was saying you can use an AIRRAID intake for a early dodge 5.2 (318ci) and it will bolt right up.
http://www.airaid.com/images/Product...300-106-LG.jpg
Old Dec 23, 2009 | 12:11 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Home made
Old Dec 23, 2009 | 04:49 PM
onetrip's Avatar
onetrip
thanks guys
Old Dec 24, 2009 | 07:59 AM
9473's Avatar
9473
Originally Posted by Dave Sponaugle
Home made
Is driving rain or snow an issue?
Old Dec 24, 2009 | 04:30 PM
Dave Sponaugle
No issue in rain, but snow, I disconnect the ram air from my air box.
The snow will cover the air filter, turn to ice and suffocate the engine if you drive long enough with it hooked up.
Old Dec 24, 2009 | 07:08 PM
onetrip's Avatar
onetrip
hello does any one know the dia of the intake on a 6.9 where the air cleaner set on it at
Old Dec 24, 2009 | 10:29 PM
Knox's Avatar
Knox
if i remember right i think its 5in its iceing or i would go run and see
Old Dec 25, 2009 | 12:47 AM
Dave Sponaugle
If I remember I can measure one tomorrow.
I know where that spare is at the garage.
Old Dec 25, 2009 | 06:09 AM
onetrip's Avatar
onetrip
ok thank you
