Block Heater Issue
Old Dec 22, 2009 | 12:56 PM
boxcar1974's Avatar
boxcar1974
Block Heater Issue
One of the guys who works for me almost torched his truck twice today by plugging in the block heater. It sparks at the plug at the engine. We unplugged it from the engine and inspected for bare wires, loose terminal, and any damage to the cord. We found some damage to the wires as they pass through the bumper. Just enough to cause problems is touching the wrang spot. We wrapped them with electrical tape until he can buy a replacement. He plugged the cord back into the black heater receptical at the engine and plugged the heater into an extension cord it sparked even worse and actually caught fire at the engine plug. We unplugged it and discovered the electric grease was burning. We cleaned it and plugged it back in and no spark.
Does the heater have a short? Anything else?
Old Dec 22, 2009 | 01:17 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Prob not....the grease caused the short to ground. Once you cleaned it, you said it didn't spark, right? And it did heat the block? Do replace the cord!
Old Dec 22, 2009 | 01:23 PM
Cowboy65's Avatar
Cowboy65
Disconnect the cord and check the heater resistance it should be around 15 ohms. Also check the heater to ground it should read as an open circuit. I suspect that it is a bad cord or loose connections at the heater terminals. Also if both the hot and neutral wires in the cord were damaged then it would cause a short circuit in the cord which would create all kinds of sparks. Did it trip the circuit breaker?
Old Dec 22, 2009 | 01:33 PM
gearloose1's Avatar
gearloose1
Something else.
Road salt.
IF the grease somehow absorbed salt and water, it can cause a short circuit.
Clean it all off.. I don't think outside connections exposed to salt spray should be greased.
A lacquer coating applied in the summer to reduce rust... sure, but grease????
Old Dec 22, 2009 | 03:30 PM
boxcar1974's Avatar
boxcar1974
I will check the ohms and circut reading for him tomorrow. It did not trip and breakers.
Thanks for the replies.
Old Dec 23, 2009 | 10:23 AM
boxcar1974's Avatar
boxcar1974
Checked it out this morning, it is reading 14.5 ohms and it has continuity. His heater did not work last night. Is the plug directional?
Old Dec 23, 2009 | 03:48 PM
firemanpat29's Avatar
firemanpat29
the element is simple just like a water heater. its ac so no its not directional. if you have 15ohms resistance, and its not shorted to ground all you need is a new wire, the wire may test (OHM) good but still have a break in it that wont pull the amps to make the heater work. Napa, oreileys, discount auto, international, or FOMOCO any of them should be able to get you the right cord.
Old Dec 23, 2009 | 04:00 PM
gearloose1's Avatar
gearloose1
Ya, it sounds like the cord or the plug... just chuck it... and put on a new one.
uponyou21
Dec 5, 2010 11:41 AM
the Goat
Mar 6, 2008 11:20 AM
my4604x4
17
Dec 21, 2005 07:20 AM
1stFordF250
Escape & Escape Hybrid
Dec 5, 2005 10:55 PM
GoEIB1
Jan 24, 2005 05:43 PM
