IAC Valve
Old Dec 22, 2009 | 08:57 AM
SNOW87's Avatar
SNOW87
IAC Valve
I have an88 f150 5.0 and im diagnosing a running condition and want to make sure my diagnoses is correct. I just happened to unplug my Iac valve and sometimes it drops about 200rpms and sometimes the rpms doesnt change at all. I cleaned it out and soaked it in carb cleaner to break up the carbon but this didnt change anything. Am I wrong or is it sticking open?
Old Dec 22, 2009 | 09:11 AM
aaron_sk's Avatar
aaron_sk
Gotta remember that the IAC is driven by the ECM based off of a signal from the TPS. Get a multimeter and test both of them.
Old Dec 22, 2009 | 10:44 AM
mprice's Avatar
mprice
Does yours have a return spring on the plunger shaft? If it does then the truck should die or run VERY slow when the IAC is unplugged. If it is the kind without the return spring then it shouldn't change when unplugged.
Old Dec 24, 2009 | 09:46 AM
SNOW87's Avatar
SNOW87
Ive tested the resistance at the IAC and also the voltage at the plug and all is checking out ok. ive done the same diagnostic procedures on my 90' model f150 w/ 5.0 and voltage/resistance is the same but as soon as i unplug the IAC it dies imediatley.
Old Dec 24, 2009 | 10:01 AM
subford's Avatar
subford
Replace the IAC as it is bad.
Do not try to clean an IAC and if you are going to clean the TB remove the IAC first.
There is only one type of IAC that can be cleaned and you have to remove the solenoid from the IAC valve before you can clean it or you will mess up the solenoid. You can not remove the solenoid with most IAC valves so you can not clean them.
hotrob
Feb 6, 2014 04:35 PM
Black Ford XLT
1978 - 1996 Big Bronco
20
Jun 8, 2011 05:44 AM
jack.w.bailey
Apr 6, 2011 06:34 AM
pdlpwr
1983 - 2012 Ranger & B-Series
43
Sep 3, 2005 06:47 PM
Skidly
Mar 17, 2005 11:41 PM
