Sponsored by: Real Truck
Roaring Sound
Old Apr 5, 2011 | 12:58 PM
jack.w.bailey's Avatar
jack.w.bailey
Roaring Sound
There is a loud roaring sound coming from the air intake from my 2004 F250. I thought it was the air flow sensor, but after changing it the noise is better but when the RPMs drop down to below 1000 and you hit the throttle it will start to roar. It will go away when you get the RPMs over 2500. I took the Idle Air Control Valve off and clean it before I changed the MAF and it did seem to help but now it is back and sometimes louder than other. Does anyone know what the problem may be before I spend anymore money on this? I am thinking the IAC valve may be out but not sure.
Old Apr 5, 2011 | 02:51 PM
Bigpipes 35's Avatar
Bigpipes 35
Are you sure its not the fan clutch sticking making the engine cooling fan roar they can make quite a racket
Old Apr 5, 2011 | 03:16 PM
5.4f250sd's Avatar
5.4f250sd
I agree with bigpipes!
Yep, I know mine roars and it is my fan clutch. I would check that out first.
Old Apr 6, 2011 | 06:34 AM
jack.w.bailey
I can place my hand over the air filter box (there is two holes in it) and the noise will change) so I don't think that is the problem?
queen of spades
Mar 11, 2015 09:36 AM
ORmetalworker
Dec 16, 2014 12:25 PM
MikeZealot
1997 - 2003 F150
Nov 22, 2014 10:51 AM
sinnedam
2004 - 2008 F150
May 22, 2013 03:01 PM
cobaum
Nov 6, 2005 10:53 PM
