New Thread (setting the idle)
Old Dec 14, 2009 | 08:00 PM
Jeff Dodson's Avatar
Jeff Dodson
Ok I found one problem with my truck and have it fixed, I think. What I need to know is, is there a correct way to set the idle on this truck ( 97 F250 5.8 / auto)
I was noticing the idle was to high and was told I could have a vacuum leak somewhere causing this and the other problems with my truck (spark knock) I have been all over this truck and cannot find a vacuum leak, timing has been checked etc... well I figured I could not make it worse and figured someone may have messed with the mechanical idle screw ( throttle lock screw, whatever its called) anyway, I turned it down to what sounded right and the truck runs ALOT better, It dont feel like something is holding it back.
Is there a correct way to set the idle screw to where it is suppose to be exactly. I figure if I got close and it made that much of a difference, then if I get it exact, it will be that much better. I appreciate any help or insight yall can give.
Old Dec 15, 2009 | 08:15 AM
subford's Avatar
subford
You did not say what kind of a truck you have so I am going to guess that it is a 49 state and over 8500 GVW.
Sounds like procedure A.
This is very long procedure so email me and I will send it to you.
Old Dec 16, 2009 | 09:30 AM
Jeff Dodson
I GREATLY appreciate the EMAIL, Now I gotta see If I can understand it enough to do the tests. Thanx again
Old Dec 23, 2009 | 11:39 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1
Originally Posted by subford
You diemd not say what kind of a truck you have so I am going to guess that it is a 49 state and over 8500 GVW.
i have a CA truck email me too?? Halflifekindofguy@Yahoo.com
im guessing its procedure B
Old Dec 24, 2009 | 06:16 AM
subford's Avatar
subford
I take it you also have a 1997 F250 with a 5.8 and it is a Cal truck and you want Jeff Dodson to email you if it worked or not.
Right?
If not you are going to send him procedure B for a 97 truck.
Right?
Old Dec 24, 2009 | 09:20 AM
Linemo's Avatar
Linemo
Jeff nice looking truck I have the same wheelbase same features except mine is dark green do you have the stainless trim at the bottom I was wondering what it would look like on my truck do you have ant good side pics showing it?
Old Dec 24, 2009 | 10:15 AM
Jeff Dodson
I put the new pics on my gallery, but I dont know how to post them on here.
No thats not stainless on the bottom, its painted Grey, this is still the factory paint
jas88
Jun 16, 2021 06:43 PM
quakerj
16
Aug 31, 2013 08:06 AM
ihateminimumwage
44
Oct 22, 2008 02:02 AM
Troy77+79
Jan 27, 2007 03:17 AM
jwtaylor
Sep 24, 2003 07:53 PM
