Winch wiring?
Dec 22, 2009 | 08:10 AM
Winch wiring?
I recently added a winch to the front of my truck. Does it make any difference which battery I hook it up to? Is there a benefit to one over the other?
Dec 22, 2009 | 08:28 AM
Both batteries are hooked up in parallel... no difference.
Dec 22, 2009 | 12:01 PM
I wired mine to the driver side battery but I don't rcall if there was any particular logic to that selection.
Dec 22, 2009 | 12:02 PM
Wire it to the shortest run... save copper.
Dec 22, 2009 | 01:19 PM
I would use the one on the drivers side.... seems like the passenger side one has the most draw when starting..... at least that's the one that always seems to die first!
Dec 22, 2009 | 01:34 PM
If that is the case, why not rotate the batteries location once a season?
Dec 22, 2009 | 08:14 PM
Connect to the same side as the alternator, that way your don't put extra strain on the cross cable.
Dec 22, 2009 | 08:30 PM
Quote:
Originally Posted by
cartmanea
THAT is the advise I was looking for!!!!
Dec 22, 2009 | 08:33 PM
Its also a good idea to beef up the grounds.
