master cylinder
Old Dec 21, 2009 | 11:41 PM
MMSGuthrie110's Avatar
MMSGuthrie110
master cylinder
Probably going to be replacing my clutch master cylinder tomarrow. never done it before so should be fun, just had a few questions. first of all what is the easiest way to get to it and replace it. Second, i'm guessing i will just bench bleed the new MC like a brake MC? also how do i go about gravity bleeding the system if i have to do that? where is the bleeder? any Help and advice is great! thanks
Old Dec 22, 2009 | 12:10 AM
Hitokori's Avatar
Hitokori
easiest way is to have the hood open lol no its a pain in the butt to bend over the fender i know especially if its lifted... yes u can bench bleed it like the brake MC i think they even come with the little plastic filling and hose if im not mistaken
gravity bleeding is to time consuming a vacuum bleeder works the fastest
or loosen the bleeder valve on the slave cylinder and run a little piece of hose into a coke bottle with some brake fluid in it and pump like hell till the bubbles stop then u should be good to go
turnrjr
Oct 30, 2012 02:07 AM
masseysbronco
Oct 29, 2010 09:02 PM
john smith jr
Aug 29, 2008 06:56 AM
BarryMc
Jan 13, 2008 06:55 AM
jhmartin7
Jan 2, 2006 10:13 PM
