Cold start problem after reflash
Old Dec 21, 2009 | 03:29 PM
Joks79's Avatar
Joks79
I have been having a cold starting problem since I had my truck in to recalibrate the speedometer for the larger tires I put on. The truck will fire like normal after letting the glow plug light turn off. It dies after I let of the starter. I proceed to crack the start again without turning the key to the off position and it fires right up. The truck is sitting for about 13 hr and temps have been single digits to the 20's. Seems odd to me that after the flash I have a problem now.
Any ideas for places for me to look?
Is there a way to check to see if the the glow plugs are working?
06 F-250 6.0L 4x4 cc
Old Dec 21, 2009 | 08:15 PM
9228.bobcat's Avatar
9228.bobcat
See if there is any codes thrown. That might let you in on your problem.
Old Dec 22, 2009 | 06:59 AM
Joks79's Avatar
Joks79
I will check tonight
Old Dec 25, 2009 | 01:29 PM
Joks79's Avatar
Joks79
i do get a code 0600. FICM Odd that Ford didn't see that code.
Old Dec 25, 2009 | 03:33 PM
9228.bobcat
Was the code po600 or po611. Guess I am not familiar with the 600?
Old Dec 25, 2009 | 03:35 PM
9228.bobcat
I would check the voltage on the FICM and make sure it is over 45 volts. If they are under then it would cause the hard cold start.
Old Dec 25, 2009 | 04:43 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
P0600 Serial Communication Link Malfunction from here Ford OBDII Diagnostic Trouble Codes - Overview .: Articles in the tech folder. Can't help with what it is though. I think P0611 is FICM performance code?
Old Dec 25, 2009 | 07:18 PM
Joks79's Avatar
Joks79
IT was P0611. I rechecked it.
Truckandute
Aug 28, 2014 01:42 PM
Jesser02EX
35
Jul 14, 2014 12:17 PM
Courtney Williams
Jan 7, 2013 09:43 AM
Splash67
May 17, 2012 12:18 PM
NAMDROF
13
Apr 5, 2011 11:02 PM
