Flathead vacuum?
Old Dec 21, 2009 | 12:20 PM
js292's Avatar
js292
Flathead vacuum?
As I'm contemplating the direction of my build, I will be doing the disc conversion for the front brakes. My question is what is the average vacuum that a flatty pulls? I know cam and other mods affect it but will a slightly modded flathead provide enough vacuum for a power brake booster?
I rememeber when I drove this thing 20+ years ago it barely provided enough for the wipers to work. (may have had a vacuum leak though)
Old Dec 21, 2009 | 06:19 PM
gdgerland's Avatar
gdgerland
bump!! bump!!
Old Dec 21, 2009 | 06:58 PM
rastiss's Avatar
rastiss
not sure how much but id think if you add a large vacuum reservior you would be fine.
Old Dec 21, 2009 | 08:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No problem, it's no different than any other engine at idle, which is when you hit the brakes.
Old Dec 23, 2009 | 09:36 PM
jmerson's Avatar
jmerson
Vac pump
You can find a nice small pump at Summit and then you won't need to worry, which is what I did for my '48 F1. I'm spending more money than I should and the last thing you need to worry about is, Will this damned thing stop when I need to. The engine is bored and stroked with a big cam, lots of Carbs and everything else I could think of. The front end has a dropped axle with power disc brakes so I figured what the heck, why not.
Old Dec 24, 2009 | 12:05 AM
js292's Avatar
js292
Thanks, sounds like the dirrection I'm going.
Old Dec 24, 2009 | 12:31 AM
BlueOvalRage's Avatar
BlueOvalRage
Another thing to consider here is that the brake booster itself acts as its own reservoir and it always has a check valve. Go out and start up your daily, let it run for a sec, and then shut it off. Now step on the brakes a few times. You'll get at least two or three good vacuum-assisted pushes before the pedal goes hard.
danlee
Mar 23, 2017 09:27 AM
daculpepp
Dec 28, 2013 09:57 PM
Jay_Sliver
37
Apr 23, 2012 08:35 AM
kellar
Jan 29, 2008 03:09 PM
Narwhal
Nov 26, 2005 08:23 PM
