Important tune up information
Mainly, you want to keep oil off of them, use the diaelectric grease on the spark plug end of the boots to prevent them welding themselves to the ceramic, and route them in the OEM clips (or get creative with nylon ties) to keep them off the manifolds.
A tip: I don't know what others do, but the wires routing for the left bank (driver's side) plugs runs through/between the legs of the plastic intake plenum. I used the baling wire fishing method to fish mine through there, as I couldn't find another way to duplicate the OEM routing, and the wires on that side do not have sufficient slack to allow routing over the top of the plenum.
IOW, don't just yank the old left-side wires out; tie a length of wire or string or floss or something to the old wire before fishing it out, so you have a way to fish the new wire in.
This is only an issue with driver's side wires.
The through-the-plenum-legs routing is a PITA to replace. Good to hear that the can be routed behind with some brands.
Ford puts the cover to prevent liability issues with sticking throttle, which Ford had a few cases of in the 80's and 90's, mostly due to faults in the cruise control system (a cover does not prevent this). Apparently there is a remote possibility that the wiper motor could loosen and fall on top of the throttle linkage. I have never seen this happen, and I have never had a wiper motor loosen, or even come close to doing so. I suppose if someone removed the motor and didn't use blue locktite, then it could in theory happen, Ford used locktite from the factory.
It just much easier to see and work on things without a useless cover in the way. Not having it also improves airflow over the top of the engine, which helps prevent and overcome things like fuel rail heat soak.
That cover is the ice shield. You need it if you live in cold climates as it can freeze the cables up if enough water and ice get on it, it will stick them closed or open.
1. The throttle is far enough back that ice and water cannot get there by gravity, even if the rubber seal along the cowl were to fail.
2. If you have that much water coming through your radiator while moving, you are probably parking in a lake
3. Regardless of either of the above, I have never seen any evidence that water of moisture ever gets there.
4. If the engine is running, it creates heat, which would melt any ice and water trapped there. If the engine is not running, the only opportunity for ice to form, then a stuck throttle is not a real concern. Sticking throttle is only an issue if it happens while you are moving.
February 05, 2011 DALLAS, Texas – Bundle up, football fans. Two of the next three Super Bowls are likely to be super cold, just like this one.
I've driven in deep snow with my AWD Aero
No Problemos.
Reqaurdless that is why its on there. The ford service manual calls it the ice shield when you have to service any part where it is removed.
I would not remove it since car makers do not put stuff on cars that are not needed.
the good news, I got to see the plastic intake, whatever you call it, and the shield is easy to remove and replace.
I can see everybody's point of view: The way this shield is mounted, I can see how it retains and increases heat, not good. I can also see how it protects the plastic throttle and cruise clamps. Maybe the trick is to drill 1/4" inch diameter holes so any heat will dissipate and at the same time air will circulate. I'm not in a Northern Climate, so the chances of ice building up are minus zero.
I might have the one off my '97 back in Duvall, and I think it's in good condition. I'll look when I'm back home in December. If you want it, you can have it.
I was at the JY today, and there was a cracked one on the '95 I was working on, so I took a couple of pics:
(click on any image for larger)
