1978 - 1996 Big Bronco
last year
Old Dec 21, 2009 | 12:00 AM
prepwd's Avatar
prepwd
last year
Hey gang..... intermitant problems cured with Motorcraft MAP sensor. I'm not sure if after market parts made my problems worse or maybe problems moved around but everythings been great after RE-replacing the MAP.
Old Jun 2, 2010 | 06:07 AM
g_k50's Avatar
g_k50
Good choice on the Motorcraft sensor.
Last year was a long time ago.
One thing is true, if it's not one thing it's another but it's always something.
Old Mar 12, 2011 | 12:52 AM
prepwd's Avatar
prepwd
OK, new problem, or maybe the same but not so intermittent. So, after a good , heavy rain when i turn the key to the on position i hear the fuel pump running. Normally i hear it run then stop and the engine starts fine. When i don't hear it stop the engine won't start and if it does [rarely] it smokes until the check engine light goes off. I tried reading the codes but got nothing. also tried changing the breaker. When i first got my Bronco i had to seal a seam or crack across the whole front portion that is under the panel between the hood and windshield. Brain box in the kick panel seems dry though. Anyway, i was hoping this would sound familiar to someone who could pull the blinders off my eyes. ALOHA
Old Mar 12, 2011 | 01:01 AM
greystreak92's Avatar
greystreak92
There is always at least one Code. ALWAYS. Fuel pressure regulator MIGHT be at the root of this problem but to be certain you will have to check for fuel in the vacuum pot or pull Codes to see what the PCM "thinks" is wrong.
Old Mar 12, 2011 | 01:04 AM
prepwd's Avatar
prepwd
i got the triple ones all around,koeo and running
Old Mar 12, 2011 | 01:06 AM
prepwd's Avatar
prepwd
also changed the fuel regulator about a year ago,
Old Mar 12, 2011 | 01:10 AM
prepwd's Avatar
prepwd
wow , i guess 2 and a half years ago , according to my posts. time flies.....
Old Mar 12, 2011 | 01:27 AM
greystreak92
Do you by chance recall what Codes you got? These will pinpoint the problems.
Old Mar 12, 2011 | 01:33 AM
prepwd's Avatar
prepwd
I think it was 111, when i looked in the code book it said all clear. 111 came out a couple different times.
Old Mar 12, 2011 | 01:34 AM
greystreak92
Ok. So, one last option that comes to mind... when was the fuel filter last replaced?
Old Mar 12, 2011 | 01:41 AM
prepwd's Avatar
prepwd
changed that also about 2 and a half years ago. I was throwing money at at my problem, changed all sensors and breakers
Old Mar 12, 2011 | 01:45 AM
prepwd's Avatar
prepwd
i'm thinking water is getting somewhere it shouldn't , but i don't know where. On dry days she runs like a champ. Actually , she runs like a champ on wet days too, but has problems after a heavy rain.
kmrbriscoe
Jul 16, 2013 11:29 PM
hedhntr
Feb 20, 2013 04:37 AM
dmanier
Oct 27, 2002 04:46 PM
nmaineron
Mar 8, 2002 01:07 PM
