starter problems on 78 ford f250
Old 12-20-2009, 07:29 PM
ajbuckhunter's Avatar
ajbuckhunter
ajbuckhunter is offline
I have a 1978 fordF250.We put a 1971 460 out of a Lincoln.The truck originally had a 351 mod.in it It still has original 4speed manual transmission in it.the starter is making a grinding sound when i try to start it. What starter will work for this application.Any info.will be greatly appreciated.
Old 12-21-2009, 07:36 AM
dhobdey1's Avatar
dhobdey1
dhobdey1 is offline
well for starters I would look for a starter that fits a 1971 460, You should crawl under your truck and inspect the ring gear that the starter engages on, it could have worn teeth, also the starter gear teeth could be worn also, take the starter to a auto supply store and have it tested for free, good luck
Old 12-21-2009, 07:58 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The starter "gear teeth" are part of the starter drive, a replaceable part.
What flywheel was used with this swap? The A/T flexplate from the Lincoln or the M/T flywheel from the 351M?
Old 12-21-2009, 01:43 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
good luck making a a/t flexplate work with a manual trans I would guess they found a new flywheel for a 460,
Old 12-21-2009, 01:50 PM
NumberDummy
I have no idea what flywheel/flexplate was used, that why I asked the question.
What was the first year the 460 was available with a M/T?
1983, in F250/350's only. No passenger car with a 460 was available with a M/T.
No 1973/79 F100/350 w/a 460 was available with a M/T either. The 460 was not available in 1980/82 F100/350's, Econolines only.
No 460's were available after 1979 in F100/150's.
Old 12-21-2009, 05:46 PM
ajbuckhunter
The flex plate is from 1978 351m M\T the flywheel has 184 teeth the starter is for the 460 it has 9 teeth
Sdw195
03-23-2015 02:52 PM
william16339
11-02-2014 11:10 AM
BossFan
05-05-2014 02:06 PM
David LaPell
01-06-2014 12:12 PM
heybrent
1978 - 1996 Big Bronco
09-06-2001 07:55 PM
Quick Reply: starter problems on 78 ford f250
