rat rod?
Old Dec 20, 2009 | 03:11 PM
newrider3's Avatar
newrider3
rat rod?
So I've got a couple old license plates lying around, and want to put them to a cool use. Namely, as a headliner and hood liner type thing for my F100. Problem is, I'm stumped as how to attach them without drilling into the panels and possibly damaging the outer skins. Anyone know of a good (cheap) method to hold/glue them onto the ceiling and inside of the hood, without one falling off every other bump? Thanks!
Kind of like this, just the other way round.
Old Dec 20, 2009 | 03:37 PM
first today's Avatar
first today
Loctite powergrab. You will have to rough up the surface to get a bond. This stuff is very strong. I use it to assemble 700 pound fake stone mantles.
Old Dec 20, 2009 | 04:19 PM
newrider3's Avatar
newrider3
From the description for that stuff, it sounds like you need at least one porous surface. Doesn't sound like it would work too good for a metal to metal bond.
Old Dec 20, 2009 | 05:13 PM
86bigred's Avatar
86bigred
how about body panel adhesive.they glue patches and panels on cars now.i can't see why it wouldn't work gluing steel to steel.
Old Dec 20, 2009 | 05:24 PM
Jmeyer1990's Avatar
Jmeyer1990
Metal is porous, just not all that porous haha.
I've worked with the stuff also, very strong.
As for the roof, it's a bi-layered roof, so drilling into it is not going to make it poke through the other end. you could do that and pop rivet them into place.
Not sure about the hood though.
Old Dec 20, 2009 | 05:34 PM
newrider3's Avatar
newrider3
Considering how dented my inner roof is, I'm not so sure that I trust myself to not poke through too far. I'll have to see. I have used the panel adhesive before, but it's costly, and requires clamping overnight.
Old Dec 20, 2009 | 06:09 PM
86bigred's Avatar
86bigred
i think most of our trucks are porous ,with the rust and all.LOL
Old Dec 20, 2009 | 06:51 PM
first today
I would spend the four dollars on a tube of loctite and give it a try. There is no clamping involved. If you are hesitant, spend the extra dollar and use the commercial grade loctite.
Make sure it is where you want it cause when it is dry it is not going anywhere.
You are correct about the smooth surface thing. I have found that it does not bond to smooth tile unless it is roughed up. As I said before, rough up the metal. Josh is correct also about metal being porous.
Old Dec 20, 2009 | 07:19 PM
newrider3's Avatar
newrider3
Alright, I'll give it a shot. I just don't want to hit a pothole and have license plates raining down on my head.
Old Dec 20, 2009 | 10:52 PM
ctubutis's Avatar
ctubutis
Velcro, buy little pieces at Home Depot or maybe even Harbor Freight.
Old Dec 21, 2009 | 04:27 AM
Blue Rebel's Avatar
Blue Rebel
Im surprised no one has suggested JB Weld!
Old Dec 21, 2009 | 09:16 AM
newrider3's Avatar
newrider3
Because JB Weld blows hard.
Old Dec 30, 2009 | 08:45 PM
magusjinx's Avatar
magusjinx
Jb Weld, Permatex, Pro Weld (from Super Glue), maybe even Pratley Steel Putty ...
Old Dec 30, 2009 | 09:13 PM
newrider3's Avatar
newrider3
I ended up just using pop rivets, with some powergrab to prevent possible vibration noises. The Loctite by itself wasn't enough. I did the front lip (where you would have the windshield to headliner trim) and the raised center strip. Also took out my beat-up kick panels and did some creative license plate bending and screwed them on.
Old Dec 30, 2009 | 09:48 PM
Jmeyer1990's Avatar
Jmeyer1990
Awesome, got some pics to show off?
