93 F250 with 5.8 EFI runs rough in wet weather
As title suggests, in wetter weather my 5.8 EFI runs rough after a rain or sometimes humid conditions. It does get better which tells me that the issue is moisture getting in somewhere.
I plan on installing a new Motorcraft coil within the next couple weeks and I installed a new solenoid about 6 months ago. On the solenoid, I think I put new ends on the wiring so they may be exposed to the elements.
Any ideas?
Any ideas?
Cool, I had a feeling it might be the coil. The coil is yellow, so it's probably an Accel unit instead of factory. Something to be said for factory replacement stuff.
Also have new wires ready to install so sounds like one way or another I'll have it licked. Thanks.
Went through and replaced cap and rotor as well as cleaing the inside of the distributor. Cap has a was corroded on #2 cylinder due to moisture getting into plug wire. Replaced plug wire and all spark plugs so it runs great, wet or dry.
For good measure, I installed a Mustang distributor boot to help prevent these issues in the future.
Good to know. That's a great test to see if it's truly fixed as well. Thanks for the tip.
my56toy
02-06-2016 10:28 PM
Dolmar9010
12-29-2011 10:06 PM
mike 96 ws6
07-20-2011 03:50 PM
F-250-Ed
Electrical Systems/Wiring
02-28-2006 06:32 PM
