HID lights installed
Old Dec 20, 2009 | 04:53 AM
AF Mezkin's Avatar
AF Mezkin
Hello everybody,
Before I PCS'd to Italy I decited to upgrade the lights on the Expy. I went with HID for the lows, highs and the driving lights. I only had enough time to install the lows and the driving light before I had to ship the expy. The results were amazing no problems with connecting, no electrical issues, I wish I had done this mod years earlier!! I went with diamond white (6000K), i'm not into the blue tint in the lights. I finnaly had the time to install the HID to the hi-beam on the Expy 2 weeks ago. The installation went as smooth as the previous install, but now the hi beam indicator in the instrument cluster has a slight glow to it. Also, most of the times the driving lights will not come back on when you use the hi beams. I have to manually turn them off and back on for them to turn back on. I've always thought that when you have a slight glow on one of your lights indicator in the cluster (head light/turn signal) it meant that the bulb went bad. Do the HID use less wattage that the Expy thinks that the bulb is bad? Has anyone done all 3 lights on there Expy and run into the same problem?
One more thing I also want to do the driving light mod where the driving lights stay on even if you turn on your hi-beams, all I have seen is instructions for 02 and below. Has anyone done this on a 03 and above? How to instructions would be great.
Thanks in advance for any info. Here are some pics of the install of the HID's;
Kit
back side of lights
low and driving lights
high beams
hi beam indicator with hi beams off
hi beams on
Old Dec 21, 2009 | 12:39 AM
jdecker's Avatar
jdecker
Looks awesome! I would like to convert mine over. Where did you get yours, and about how much can I expect to spend?
Old Dec 21, 2009 | 08:21 AM
AF Mezkin's Avatar
AF Mezkin
jdecker, I purchased the kits from ebay. The total was 180.00 for all 3 lights with free shipping (each kit purchased seperatly). The seller is a stand up seller, one of the ballast had a faulty connection, I emailed him with my problem and he promply sent a replacement ballast. The install is very easy, all plug and play. the only mod that was done was to make a small hole on the two larg rubber grommets on the back side of the head light so the wires can pass though (as you can see in the pic) which I sealed with black RTV adhesive/sealant.
Old Dec 22, 2009 | 11:17 AM
04markIII's Avatar
04markIII
night pics?
Old Dec 23, 2009 | 09:37 AM
AF Mezkin's Avatar
AF Mezkin
markIII do you want me to post some night pics? Or are you asking if I took the pics at night?
Old Aug 19, 2010 | 01:30 PM
04markIII's Avatar
04markIII
resurrected!
just got some ddm tuning 9006 hid's today. 6000k, 35w. installing tonight, as i'm taking a trip to honey brook pa tomorrow night. sticking with the stock halogen high beams, since when i had a remote start unit installed, somehow the tech did something, so my lows stay on when the highs are activated.
Old Aug 19, 2010 | 02:15 PM
Totoro's Avatar
Totoro
Who was the seller you dealt with?
Where did you mount the Ballast for the main headlights?
I was thinking of starting with the Fog Light/DRL's, lots of space down there.
elgemcdlf
277
Dec 19, 2018 12:29 AM
LA2005F250
6.7L Power Stroke Diesel
Mar 28, 2013 12:05 PM
WarOzz
87
Apr 30, 2012 11:21 AM
ChiefsFan
Kansas Chapter
232
Mar 10, 2005 01:07 AM
