1978 - 1996 Big Bronco
REAR END SWAP
Old Dec 20, 2009 | 01:53 AM
bailenforcer's Avatar
bailenforcer
REAR END SWAP
I have a 1995 Bronco 5.8 with a H9 rear end and I need to replace it; I have a 5.0 Bronco with an I9 rear end and was wondering if it would be wise to swap out these two with out issue. I've been to many local grave yards but I can't seem to locate a H9.
any advise would be greatful.
Old Dec 21, 2009 | 08:34 AM
northeaster79's Avatar
northeaster79
well the H9 is a 3:55 ratio rear with limited slip,3800lbs rating
I can't seem to find anything for the I9,I think and combination of two digits ending with 9 is 3:55 ratio,the I may just be a different weight rating.I'm sure someone will come along that knows more about this then I do about this.hope this is of some help to you.
Old Dec 21, 2009 | 08:53 AM
bailenforcer
I should be more specific; the tag in the door jam is fadded a bit and looks like it reads I9 but it may be 19
Old Dec 21, 2009 | 09:14 AM
Conanski's Avatar
Conanski
It's likely a 19 and that's a 3800lb 3.55 open diff. why you removing the LS diff?
Old Dec 21, 2009 | 10:18 AM
northeaster79
that makes more sense the I9,I looked high and low for that one haha.
Old Dec 21, 2009 | 01:16 PM
bailenforcer
The current rear end is blown and I cant seem to locate a H9 anywhere localy; but what can I expect for a FREE truck! Needs a little body work and a rear end and its good to go. Set almost a year put a battery init and it fired right up! Doing full tune up; tranny & cooling system flush and once I get the rear end done it'll be on the road
Old Dec 21, 2009 | 01:31 PM
northeaster79
you could always get the 19 coded 3:55 and put in until you have time to rebuild the trac-lok carrier from your old rear and install it into the truck then.
Old Dec 21, 2009 | 06:22 PM
bailenforcer
Yea thats what I was thinking of doing but didnt want to do it if it would cause other issues; like causing the transfer case to fall out on the highway!
Old Dec 21, 2009 | 08:43 PM
northeaster79
rear swap
no it will be fine,same ratio as what you have,won't cause any issues other then the rear will be a one wheel peel.
and thats not a huge deal,speciallly if only temporary,I just bought a ford motor sports king cobra trac-lok with carbon fiber clutches for my truck.it was around $400 canadian for the whole brand new carrier with warrenty,I was just over an hour doing the whole swap.
I would suggest going that route if you can.
and in case nobody has said it yet,welocme to FTE!!!
Old Dec 23, 2009 | 10:07 AM
bailenforcer
I'm going give it a go; I just opened the original H9 rear end to find the carrier is broken in two and the shims are melted on one side.
So I opened the 19 and it looks to be in decent shape; no excessive ware on and gears of splins that I can see so tomorrow night it will go in. Im off work tonight and the truck is here at the shop; tonight is just going to be me and by buddy Budweiser.
Learned a long time not to drink adn do repairs on my vehicles! lol
Oh and thanx for the welcome!
derbyhunter5
Apr 13, 2015 02:37 PM
ruffneck30
1997 - 2003 F150
Jun 24, 2011 10:18 PM
myklstrng
1966 - 1977 Early Broncos
Dec 31, 2010 09:06 AM
Duct Tape Racing
21
Aug 15, 2010 04:17 PM
rocks'r'friends
1997 - 2003 F150
Oct 5, 2009 04:49 AM
