Lucas oil
Old Dec 19, 2009 | 06:53 PM
crazymut's Avatar
crazymut
Lucas oil
Does anyone here use Lucas semi synthetic ATF? If so are you happy with it?
Old Dec 19, 2009 | 07:49 PM
schlepprock250's Avatar
schlepprock250
I've never used Lucas ATF,but i would NEVER put Lucas anything in my engine again...Just my.02 worth
Old Dec 19, 2009 | 07:56 PM
DieselCamper01's Avatar
DieselCamper01
I have not heard a lot of positives about Lucas in general. Have heard nothing about their ATF.
Old Dec 19, 2009 | 08:57 PM
crazymut's Avatar
crazymut
Thanks for the responses. Lucas so far is the only semi synthetic I have found.
Old Dec 19, 2009 | 10:30 PM
big poppa's Avatar
big poppa
I'm sure the Motorcraft has a blend, might want to look into that, its readily available at the dealer, gonna pay though.
Old Dec 19, 2009 | 11:35 PM
Fire Rooster's Avatar
Fire Rooster
please enlighten me. I like Lucas fuel tx. Am I missing something?
Old Dec 19, 2009 | 11:53 PM
mueckster's Avatar
mueckster
Autozone sells a synth blend: AutoZone.com | 1 qt. Mercon V multi-vehicle synthetic blend automatic transmission fluid | 1 qt. Mercon V multi-vehicle synthetic blend automatic transmission fluid for $3.99/qt.
We used to use Coastal lubricants at the auto repair shop where I worked for almost 15 yrs after high school. I have had no bad experiences with their products.
It is also available at their Woodland store near you, Terry.
Old Dec 20, 2009 | 12:04 AM
crazymut's Avatar
crazymut
Thanks for that info. I will look into that. I was thinking of running regular merk V for 5 to 10 k and then flushing and running the blend. Filling this trans is not cheap.
Old Dec 20, 2009 | 06:50 AM
mechelement's Avatar
mechelement
I've noticed Autozone pushes Lucas Oil like a drug dealer pushes drugs. An Autozone associate was really turning on the pressure to get me to buy some Lucas Oil fuel additive for the truck yesterday.
FWIW, I run Lucas oil in my Jeep's transfer case because it's not clocked level. It works awesome. Lucas oil travels up all those gears and keeps em wet. I haven't used it in anything else.
Old Dec 20, 2009 | 07:57 AM
DieselCamper01
You don't want to use additives in our diesel's oil. The oil drives those injectors. Additives and injectors don't get along to well. I know, that is not a very technical answer but the oil does a good job on it's own of protecting our engines. Why add an unknown into the equation?
Old Dec 20, 2009 | 01:51 PM
rbaker6336's Avatar
rbaker6336
Lucas seems to climb and coat the gears real good,but I always wondered how well it lubes the shafts and bushings
fearfactory
Oil & Lubrication
40
Aug 30, 2016 04:00 AM
tsgtbdl
Jul 13, 2011 07:24 PM
HuntM
Nov 30, 2010 08:45 PM
wcurtis
Jan 22, 2007 07:41 AM
JCastellaw
Oil & Lubrication
51
Feb 15, 2004 07:59 PM
