Clutch not working
Old Dec 19, 2009 | 03:55 PM
MMSGuthrie110's Avatar
MMSGuthrie110
Clutch not working
i have a 96 f150 4.9l with a 5spd. it hasn't been driven much letely but i went out to drive it today and it seemed fine at first. then when i got down the street i had it in nuetral and i pressed the clutch in to put it in gear and it would't go in gear. the clutch pedal was stuck down and i had to pull it back up. it kept sticking every time i did it. i would press the clutch all the way to the floor but it would not let me put it in gear. the clutch fluid is full. what is the problem?
Old Dec 19, 2009 | 04:57 PM
tivoklr's Avatar
tivoklr
Not absolutely sure but when my slave cylinder went **** up, this was the symptom.
Old Dec 19, 2009 | 08:29 PM
MMSGuthrie110
i have been reading dome other posts about it and i guess the first thing i will do is bleed the system to see if that helps. can anybody give me some tips for doing that i have never done it before? why couldn't they just left them cable clutches???
Old Dec 19, 2009 | 09:13 PM
1990F2504604x4's Avatar
1990F2504604x4
Not sure about the small gas motors but when the slave in my '90 460 went it did the same thing, had a leak, and no you cant bleed them if they are like the system the big gas ones have, they are sealed, have to bench bleed them.
ced715
1983 - 2012 Ranger & B-Series
Dec 17, 2023 11:26 PM
ThatGuy79
32
Nov 24, 2014 10:16 AM
Bruiser 1
Electrical Systems/Wiring
Jan 27, 2008 02:24 PM
Mr. Bob
52
Aug 26, 2007 10:02 PM
88grandmarquis
Jun 13, 2004 03:35 PM
