Sponsored by: Auxito
My engine stalls when braking!
Old Dec 31, 2009 | 09:11 PM
stan49's Avatar
stan49
well the egr tested fine but the ports in the throttle body were compleatly closed off from carbon so i cleaned them out. and that didnt fix the problem. but when i test drove it, the truck still wanted to stall unless i manually shifted it to first or nutural. so as soon as it warms up or manually shift it its fine i have no clue what it could be. i wouldnt think the tps anyone have anything, thanks for all the in put by the way!!!
Old Jan 1, 2010 | 02:55 PM
stan49's Avatar
stan49
possable bad torque converter???
OK! i changed the tps and nothing! but i was messing with the shifter while sitting in a parking lot and i didnt even have to move to make it want to stall, all i had to do is move the shifter from second to first or drive to first it didnt really matter, im starting to think its a trans solenoid, or the torque converter or even worse the trans its self
Old Jan 8, 2010 | 07:38 PM
stan49's Avatar
stan49
its was the torque converter, was stuck locked $1200 later at the shop
Buttons728
Mar 10, 2016 08:57 PM
Mark DeDo
1997 - 2003 F150
Feb 3, 2012 12:15 PM
Motoshrump
Apr 24, 2011 09:08 PM
jimmiwan
1983 - 2012 Ranger & B-Series
Sep 7, 2009 08:43 PM
Greymon
1997 - 2003 F150
Feb 2, 2005 07:57 AM
