Is brake bleeding tool any good. ????
Old Dec 18, 2009 | 07:01 PM
maevans's Avatar
maevans
I'm thinking I should buy myself a Christmas gift, and this just might be it - Motive Products Shopping Cart Ford Three Prong Bleeder 0107
I like that it only take one person to use.
Has anyone used one before, and is it worth the money ?
Old Dec 18, 2009 | 07:07 PM
Waltdog's Avatar
Waltdog
of American machinists
I bought one a a while back. It seems well built. The hardware is really nice stuff. I have not had a chance to use it yet
Old Dec 18, 2009 | 07:14 PM
F350-6's Avatar
F350-6
Something else to consider is these Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Pete turned me on to them, but I ended up with the wrong ones so they didn't fit, but I like the concept.
PaysonPSD's Avatar
PaysonPSD
Hi Mark,
That's the one Andy (Fat Diesel) uses in His Write-Up.
The "just use gravity method" works, but takes awhile.
Fat Diesel's method takes about two beers.
The gravity method is a 12 pack.
Old Dec 18, 2009 | 07:16 PM
big poppa's Avatar
big poppa
Looks like a nice tool, just had my wife help me bleed my brakes on my truck then she went shopping and bleeded my wallet, lol, Christmas shopping, its all good.. Nobody to help you Mark???
Old Dec 18, 2009 | 07:19 PM
maevans's Avatar
maevans
Is $ 65.00 about what you paid for yours ? And did you but kit # 0107 ?
Old Dec 18, 2009 | 07:23 PM
PaysonPSD's Avatar
PaysonPSD
Mark,
If you have a compressor and can order the 3-prong Ford adapter separately you can save a bunch.
Old Dec 18, 2009 | 07:27 PM
spdmpo's Avatar
spdmpo
I have one of those, and also a brake bleeding vacuum pump. They work in a pinch when there's no helper, but I prefer to get the wife out there to pump the brake pedal and see if I can't convince her to get dirty.
Seriously though it always seems to do a better job with a helper to push on the brake pedal when bleeding the brakes. I only use the vacuum or pressure method if I can't find a helper.
Old Dec 18, 2009 | 07:28 PM
swaybar's Avatar
swaybar
Originally Posted by PaysonPSD
Hi Mark,
i've never used it but have heard about it "gravity". does it require opening all bleeder screws an just letting it sit for awhile?? and/or the mastercylinder??
Old Dec 18, 2009 | 07:32 PM
PaysonPSD's Avatar
PaysonPSD
That's it. Just don't ignore it and let the reservoir run dry or air will get in the system.
Old Dec 18, 2009 | 07:36 PM
swaybar's Avatar
swaybar
how does the reservoir run dry if your not pumping the system??
maevans's Avatar
maevans
I LIKE..... Thanks for the link.
Hi Mark,
Hello Sir, Thats where I seen it. I'm looking for a easyer way.
Originally Posted by big poppa
Looks like a nice tool, just had my wife help me bleed my brakes on my truck then she went shopping and bleeded my wallet, lol, no pun intended.. Nobody to help you Mark???
I like doing my PSD maintains first thing early on Saturday or Sunday morning. I'm a morning person and the wife is not.
I don't like waiting for people when I have work to do, I'm just inpatient that way.
Old Dec 18, 2009 | 07:39 PM
Izzy351's Avatar
Izzy351
You can build your own out of a small chemical pump and some simple parts. It helps if you know someone with milling skills:
Old Dec 18, 2009 | 07:45 PM
Waltdog's Avatar
Waltdog
Yhea price sounds right. I saw them using one on an episode of Trucks. Fill er up with new fluid. Attach to master, presurize and bleed away.
ETA #0107 3 prong is the one I bought
Old Dec 18, 2009 | 07:47 PM
maevans's Avatar
maevans
That's nice Joe, How much air pressure do you use - 10 psi ?
