What do you think..
Old Dec 21, 2009 | 05:53 PM
rcorcich's Avatar
rcorcich
The truck runs great no problems there, the little bit of smoke during the colder weather ,like you said is probally from the moisture and colder temps.I have the banks 4" turbo back monster exhaust and still have the kitty on.
I'm waiting to see if the HS's will cure the stiction on the longer crankin time to start.
Old Dec 21, 2009 | 05:58 PM
9228.bobcat's Avatar
9228.bobcat
The only thing I have not done and plan on doing may be tomorrow is check the voltage in my FICM. Maybe you should try that as well. How do you know that there is an injector striction problem? Codes? Run rough?
Old Dec 21, 2009 | 06:20 PM
rcorcich's Avatar
rcorcich
I don't know how to check the voltage on the ficm,and stiction maybe someone can chime in here and explain it better than me but is defined as a static friction that keeps a object from moving in our case our injectors from working properly.maybe run a bit rough or longer crankin time to start ect.
Old Dec 21, 2009 | 06:30 PM
9228.bobcat
That was my question on the injectors. How do YOU know that there is a problem with them? I would want to know for sure before adding any additive in the oil. It shouldn't hurt anything adding hss. Here is a couple of links to the procedure and pics of the FICM.
FICM pictures by DrQuad - Photobucket
Ford Truck Enthusiasts Forums - bismic's Album: FICM
Let us know what you find out. Eric
Old Dec 21, 2009 | 06:47 PM
rcorcich's Avatar
rcorcich
Thanks for the links for the ficm, search the forum for hot shots secret, there has been lots of discussion on it some positive, some not so positive,i have used before with no problems as maintaince, now I have longer crankin time to start and want to see if this helps by cleaning the oil side of the injectors.or check out there web site,and there explainations.
Old Dec 21, 2009 | 08:02 PM
9228.bobcat
That's cool. Hope all works out for you.
Old Dec 24, 2009 | 10:38 AM
DrQuad's Avatar
DrQuad
Here is a PDF of the procedure, the pics are better.
Ford Powerstroke Diesel Forum
Old Dec 24, 2009 | 11:46 AM
9228.bobcat
Checked my volts from my ficm and it read 48.4V. So I still think it is the moisture form the straight pipe and no cat, taking longer ot warm up. Have you checked yours yet rcorcich <!-- BEGIN TEMPLATE: postbit_onlinestatus -->?
Old Dec 25, 2009 | 08:15 AM
rcorcich's Avatar
rcorcich
not yet, i'll try to do it tomorrow and post my results,
Merry Christmas to ALL
Rich
Old Dec 27, 2009 | 11:08 AM
rcorcich's Avatar
rcorcich
Thanks All for the links and procedures,
This is the info under the cover of the FICM :
652103.03.10
Rev. A
08 2008
key on engine off :47.9-48.0 / 47.8-48.0 / 47.8-48.0
key on engine running : 48.1 /48.1
No codes from engine,but still have longer crank times ?
Rich
427 fordman
33
Jan 9, 2017 11:10 PM
Fordenthusiasts
Nov 5, 2014 12:46 PM
garrett_browning
Jun 18, 2014 07:47 PM
Get Pumped Saltwater
Feb 22, 2011 06:55 PM
