rear axle nut torque spec
Old Dec 18, 2009 | 05:51 PM
RoughIdle's Avatar
RoughIdle
I have a 1997 F250 with a 460. What is the torque spec for the nuts that hold the rear hub on? It is a full float axle. Thanks
Old Dec 18, 2009 | 07:21 PM
Ford_Six's Avatar
Ford_Six
I don't think there is a torque spec for the inner, just set it like the front wheel bearings on a 4x4, but the outer should be around 45-50ft/lbs, then bend the tab over to lock it.
Old Dec 19, 2009 | 08:01 PM
RoughIdle's Avatar
RoughIdle
45 ftlbs was way to much. Couldn't even turn the hub. So I just hand tightened until there was no play in the hub up and down or side to side. The nut has a type of collar around it that as it starts to tighten up clicks and prevents the nut from backing off.
Deluxe06
Nov 7, 2016 05:09 AM
jawdoc
Sep 30, 2015 02:15 PM
jawdoc
Sep 30, 2015 09:41 AM
stbernard
Sep 15, 2015 11:00 AM
flamesoldier
May 21, 2013 09:59 AM
