1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Transmission cooler lines direction of flow.
Old 12-18-2009, 03:44 PM
RailDawg's Avatar
RailDawg
RailDawg is offline
2001 Ford Expedition. Is the bottom line from the radiator the return line to the transmission? Thanks as always!
Old 12-18-2009, 05:58 PM
madsonp's Avatar
madsonp
madsonp is offline
I don't know for sure, but I'd think you could run the vehicle, feel the lines, and the cooler of the two would be the return line.
Old 12-18-2009, 07:23 PM
svchareta's Avatar
svchareta
svchareta is offline
I am not sure which transmission you have, so I will list the lines for the 4R70 and the
4R100. Hope this helps.
The return line to the 4R70W is the top line on the transmission.
so the top line on the transmission is the cool line IN from the rad.
bottom line of transmission is hot line OUT to the rad.
4R100 Front (Forward) line on the transmission is the OUT line (Hot) to the rad.
The Rear line on the transmission is the IN line (Cool) from the rad.
Old 12-19-2009, 08:04 AM
RailDawg's Avatar
RailDawg
RailDawg is offline
Thanks for the quick responses. Does the line from the transmission usually go to the top of the radiator with the return line at the bottom of the radiator? Thanks.
Old 12-19-2009, 11:53 AM
svchareta's Avatar
svchareta
I have two expeditions. One is a 1999 the other is a 2004. The 99 has a 4R100 transmission with an auxillary cooler.
Old 12-19-2009, 12:02 PM
svchareta's Avatar
svchareta
I have two expeditions. One is a 1999 the other is a 2004. The 1999 has a 4R100 transmission with an auxillary cooler. The 2004 has a 4R70 and Top line on the radiator is the return line (Cool) to the transmission. The Bottom line on the radiator is the In Line (Hot) from the transmission.
(Sorry about the incomplete previous post, hit the wrong key)
bbsitum
1997 - 2003 F150
15
11-24-2017 08:49 AM
gary's1950F1
12-12-2016 10:53 PM
SuperDad
1978 - 1996 Big Bronco
01-15-2016 12:24 PM
blowin smoke
2004 - 2008 F150
06-18-2011 11:47 AM
bvieages
Escape & Escape Hybrid
05-31-2011 09:48 PM
Quick Reply: Transmission cooler lines direction of flow.
