Aluminum transmission cooling lines
That looks great, but fuel line is not rated for oil use, so I would double check what you have there. Oil will break down fuel line from the inside and when it fails oil will go everywhere. Unfortunately I learned that from experience long before the internet
Now I make sure I use high pressure hose rated for oil use.
Trans cooler lines blend for the
Dave
I agree. The metal trans cooler lines are 3/8 fuel lines. The flex lines are oil related (engine-trans-powersteering).
I used special high pressure hose for the p/s pressure hose and oil compatible hose for the p/steering return and trans cooler lines.
Working well so far.
Thanks
Dan
Thanks
Dan
Cooler lines
The hard lines are steel so I am not worried and I went to great expense to find hose that is compatible with transmission fluid and powersteering fluid. So, I have no worries.
But thanks for the reminder as it would be easy to purchase the wrong type of hose for the job. Better to use the right stuff the first time than have to do it over again months later.
Just like the Moog tie rod ends purchased from Rock Auto and installed on the Jag ifs two years ago. The dust boots have rotted while sitting in the garage. Never made it to the road.
Now I have to replace the boots.
I still trust Moog parts. Not many other quality choices out there. A couple years ago I bought a couple Raybestos branded inner tie rod ends for my Lincoln. A few months after installing one of them separated from the rack end, while crossing a railroad track about 50 feet from a red light (read: driving slowly.) After towing it to the shop I found that the threads in the ends were to blame. Replaced with Moog ends and barked at myself for not having bought them in the first place. No problems since (taunting fate now so who knows how long they'll last.)
With so many parts manufacturers being bought up and consolidated since the inception of NAFTA, plus the expansion of Autozone, O'Reilly's, et al (a.k.a. "Third Time's a Charm Auto Parts" - 1st one is wrong, 2nd is already broken in the box and 3rd just might make it around the block), it's really difficult to rely on any suppliers these days. I've pretty much assumed the position of if something isn't available at the OEM level I head for NAPA.
Encho
08-04-2014 11:10 PM
stubborn66
03-03-2011 07:16 PM
