1997 expedition, pass. side front caliper keeps freezing up?
Old Dec 17, 2009 | 02:55 PM
PJSPNY's Avatar
PJSPNY
it's done it 4 times in the few year's my father owned it and now that it's mine, i'd like to know if nayone else has the same problem.
it doesn't completely freeze up, but it will randomly keep brake pressure until wears everything out. all the lines have been changed, along with the caliper/rotor every time...
any help will be apreciated.
Old Dec 17, 2009 | 08:00 PM
eallanboggs's Avatar
eallanboggs
Sticking piston. Replace caliper and bleed system.
Old Dec 17, 2009 | 09:11 PM
1whoseeks's Avatar
1whoseeks
Remember to use proper lube on the caliper guide pins each time you replace brake pads.
Old Dec 17, 2009 | 09:13 PM
PJSPNY's Avatar
PJSPNY
as i said in my opening post, it's been replaced every time it happens and it keeps happening...
Old Dec 18, 2009 | 06:54 AM
1whoseeks's Avatar
1whoseeks
What about the brake proportioning valve? Since the problem is always the same side. I would be shopping for a good mechanic. Someone who can fix the problem if not the first time at least the second time. Around here its not how fast you can go, it's how fast can you stop.
Old Dec 20, 2009 | 12:40 AM
98expeditionXLT's Avatar
98expeditionXLT
Have you changed the flexible brake line?
Old Dec 20, 2009 | 12:25 PM
Moto Mel's Avatar
Moto Mel
I have to agree with the above response and suggest a hard look at the ABS as well.
Old Dec 20, 2009 | 12:30 PM
PJSPNY's Avatar
PJSPNY
i'll definitely look into these things. thanks guys!
Old Dec 20, 2009 | 03:12 PM
fordtech08's Avatar
fordtech08
I'd look at your hcu it's connectted to you abs mod
Old Dec 20, 2009 | 05:01 PM
PJSPNY's Avatar
PJSPNY
what's an HCU?
Old Dec 20, 2009 | 06:02 PM
fordtech08's Avatar
fordtech08
hydraulic control unit, it's what the brake lines screw into,
Old Dec 20, 2009 | 11:21 PM
PJSPNY's Avatar
PJSPNY
oh gotcha, thanks. i'll be looking into this stuff once the 2 feet of snow melts away.
Old Oct 6, 2011 | 10:54 PM
FSTOKLEY's Avatar
FSTOKLEY
HAVING THE SAME PROBLEM WITH THE DRIVERS SIDE FRONT CALIPER
I am having the same problem with my 97 expedition as well! i have replaced the rubber line and the caliper bleed the line(no Air)
as long as the vehicle is off and you pump the brakes the caliper releases but not completly still drags! If i start it and hit the brakes it takes all the strength i have to turn the rotor. i have looked and i have not found a proportioning valve so i take it that it is built into the abs pump?
I guess my question is can i bypass the abs to just the front brakes and set it up like the old style of brakes and install a proportioning valve! off of a older ford like a truck with no abs system?
1997, bauer, brake, caliper, calipers, change, eddie, expedition, fixed, ford, freezing, front, lube, pads, proportioning, valve
Old Oct 7, 2011 | 06:38 AM
eallanboggs
How about flushing the old fluid out and replacing it with new clean, debris free fluid. Suck the old fluid out of the MS resevoir with a liquiVac and replace it with new clean fluid. Bleed each wheel(and ABS unit) until fluid runs clear(changes from dark color to lite). There has to be a restriction somewhere and trash in the lines is a good place to start. Even if it doesn't solve this problem it's a good idea to change the brake fluid as it does get contaminated with high mileage and years of use. You can even check the brake pressure at each wheel once the old fluid has been pumped out with a brake pressure gauge.
Old Dec 25, 2011 | 12:28 PM
apgarassoc's Avatar
apgarassoc
Any Resolution?
I'm having the same problem with front driver side (2004 w/177K) caliper. Initially had driver side caliper lock up so I replaced both front calipers and pads. Now I'm still having the same problem (not quite as severe) with the driver side caliper not fully releasing. I initially did not replace the rotor and still had occasional pulsating. When I went to replace the rotor, I could not retract the new caliper piston without opening the bleed nut. Other side of front brakes was no problem whatsoever.
I guess my options are the HCU or the ABS controller or bad replacement caliper. The ABS still works no problem with no codes. Hence, I'm thinking it could be the HCU. Difficult job or not? Probably replace all brake lines at the same time. No, I have not been fully bleeding out all brake fluid when I do my brakes.
Xwild
Sep 5, 2016 07:25 PM
ajbrown208
May 19, 2016 06:42 AM
nilzlofgren
May 17, 2016 04:40 PM
daveplot
Aug 21, 2015 05:46 AM
RangerDJB
Escape & Escape Hybrid
Jul 1, 2015 07:55 AM
