lift kits
Old Dec 16, 2009 | 08:13 PM
arkredneck's Avatar
arkredneck
lift kits
alright i'm coming down with a BAD case of PMS and my truck has worn out axle pivot bushing and spring bushing and i'm the type who can't never put nothing back to "stock" so i been looking at lift kits and i want new leafs in the front and rear and either a 4'' or a 6'' and no blocks just wondering if you guys knew a "cheaper way to do this. and i can't seem to tell if any of the kits that come with the drop brackets for the axle pivot brackets come with the bushings in them or it is just a drop bracket you bolt the old bracket to any help would be greatly appreciated!!!!
Old Dec 16, 2009 | 08:45 PM
-ZIXXER-'s Avatar
-ZIXXER-
Skyjacker will probably be the best kit for front and rear springs. Most lifts do not come with pivot bracket bushings, but can be picked up at o'reily for $20. The pivot brackets will replace your old ones. it will come with new spring bushings
Old Dec 16, 2009 | 09:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe
go with the skyjacker kit, and opt for the heavy duty drop bracket, excellent kits, and get polyurethane pivot bushings
Old Dec 18, 2009 | 06:10 AM
arkredneck's Avatar
arkredneck
i been looking at the bronco graveyard site and they got a superlift kit for about $1500 to my door with new springs and shocks all the way around. every other place i look the kits are around $2000. anyone know a cheaper place to order kits??
also i was looking at the stock leaf springs and noticed they got some extra heavy duty ones if i was to bolt those on my truck would it lift it any higher than stock ride height or just make it ride more like a log truck???
Old Dec 18, 2009 | 06:14 AM
-ZIXXER-'s Avatar
-ZIXXER-
I doubt you'd get any height out of a stock heavy duty replacement. It probably just gives more payload capacity and like you said will ride foe like an old horse and buggie
Old Dec 18, 2009 | 08:45 AM
RRranch's Avatar
RRranch
My buggy rides pretty darn nice depending on the horse pulling it.
I'd recommend fixing your front end to stock. Your alignment nightmares haven't even begun untill you put a lift on it.
Old Dec 18, 2009 | 08:48 AM
heathrunkles's Avatar
heathrunkles
I had the heavier springs from broncho graveyard---rode like crap and no additional height. I went with the skyjacker lift--4"--ride better but I will be pulling it off in the near future to go with a 5" RSK and SD "V" codes on the front. I will probably keep the skyjacker springs in the rear though.
Old Dec 25, 2009 | 03:21 PM
arkredneck's Avatar
arkredneck
anyone run this lift??? good price?? know any better prices or other lifts anywhere else????
4" Ultra Lift Kit F250 4WD 1987-97 Power Stroke Diesel
Old Dec 25, 2009 | 11:43 PM
c00nhunterjoe
1400 bucks? ride at your own risk, those axle pivot brackets are junk. call skyjacker and price out their kits, i cant see it being much more then that price and the heavy duty drop brakcet is a must
Old Dec 25, 2009 | 11:58 PM
c00nhunterjoe
you will have to call them to get a quote, they redid their site and they dont have all the pics up of th ekit components but it looks like its between 1400 and 2000 for a complete kit, just ask for a quote with the heavy duty one peice drop bracket.
Old Dec 27, 2009 | 08:13 AM
arkredneck's Avatar
arkredneck
ok so i looked at the skyjacker kits joe and found them for around $2000 on skyjackers website
also found a place called 4wheelonline.com and the kits are about $500 cheaper with the same part numbers as skyjackers website\
anyone ever used this 4wheelonline.com place?
Old Dec 27, 2009 | 08:17 AM
arkredneck's Avatar
arkredneck
look like a decent deal to yall
Ford, Skyjacker Suspension Lifts for Ford 87-98 F-250 (IFS) 4WD Kit Standard Brackets with Blocks & U-Bolts
Old Dec 27, 2009 | 07:12 PM
-ZIXXER-'s Avatar
-ZIXXER-
doesn't seem too bad. If I were you, I'd make sure to get dual stabilizers and the nitro shock upgrade while you're at it
Old Dec 27, 2009 | 08:02 PM
c00nhunterjoe
nitro shocks are on my list but the hydro's are awesome too.
the dual steering stabilizers are nice too, glad i have them on my rig
Old Dec 28, 2009 | 08:56 PM
PIKE's Avatar
PIKE
I havent posted on this site for quite a while,but I cant resist this one. Take the money you are going to **** away on a junk lift kit and pick up a dana 60.You are going to have all that 50 junk out of the way and you will be much happier in the long run while you are in there do a shackle flip on the front and rear.Been there done that.
