puzzled
Old Dec 20, 2009 | 01:42 PM
mikemoon's Avatar
mikemoon
puzzled
05 5.4 running rough had plugs changed an vacuum checked no leaks still when in gear it has a little shake to it
Old Dec 20, 2009 | 03:00 PM
fordtech08's Avatar
fordtech08
you need more info, have you checked for codes is it just at idle or all the time
Old Dec 20, 2009 | 09:44 PM
mikemoon's Avatar
mikemoon
more info
it only does it when in gear at a light or stop
no code brought it back to shop he tested it for vacuum leak it did not show any leaks anywhere he told me to run some cleaner in it which i have done just had all plugs changed and one injector i was wondering if it could be o2 censer
Old Dec 20, 2009 | 11:22 PM
prepwd's Avatar
prepwd
fuel
I used Lucas injector cleaner . It took running through the whole tank before it cleared up but it was worth the wait.$$$$
Old Dec 21, 2009 | 12:58 PM
fordtech08's Avatar
fordtech08
could have a leak in your brake booster, with it in gear put your e brake on( make sure it works) then take your foot off the brake, if the problem goes away then it's your booster, you could also pop the hose off your booster with someone holding the brake for you just plug the end of the hose with your thumb, should smooth out after a few seconds if it's your booster
Old Dec 22, 2009 | 04:07 PM
mikemoon's Avatar
mikemoon
update
went to the dealer he said it need to have computer reset how do i do this
he was saying something about disconnect battery then start then ac on then parking brake in gear ???????????
Old Dec 22, 2009 | 04:14 PM
fordtech08's Avatar
fordtech08
why didn't they reset the comp while you were there?
