Sponsored by: Real Truck
HELP WITH KNUCKLE SEALS
Old Dec 17, 2009 | 11:11 PM
EXv10's Avatar
EXv10
Originally Posted by 5.4L to Freedom
Lol well thanks for the advice, but what really discouraged me is when I constructed the seal tool out of galvanized pipe... I broke the 1-1/4 end cap, checked to see if I made any progress and my seal fell apart and then fell off the axle
Did you grind the flange down to 3 7/8" ?
Old Dec 18, 2009 | 10:49 PM
tawells01's Avatar
tawells01
I did mine recently. I thought about constructing the seal tool, but decided buying the pipe etc and making it wasn't worth it when Carquest could order the OTC tool for me ($66 at 8:00am and I had it by noon). Installed the seals in a couple of minutes. Ruin a seal and you almost bought the tool.
Old Dec 18, 2009 | 11:01 PM
EXv10's Avatar
EXv10
$66 Yikes, I would gladly make the tool
Old Dec 18, 2009 | 11:11 PM
1975StroppeBaja's Avatar
1975StroppeBaja
x2 on that. Its not like making the tool is just some crazy idea, lots of folks on here have used it with success, me included.
Old Dec 19, 2009 | 12:22 AM
tawells01's Avatar
tawells01
Didn't say making the tool was a crazy idea. Have made plenty of tools and more sophisticated equipment than this, but there comes a point where my time is worth more than $66 dollars, especially when I'm working about 70 hours a week. If I can order it on the way to work, pick it up at lunch and have the front end back together that night, during the work week, I'm going to do it.
Besides, I would have had to buy the pipe etc. to make the tool anyway.
Old Dec 19, 2009 | 02:17 AM
ironmine's Avatar
ironmine
If you want the official OTC tool to do the job .... thats cool. (I've bought a couple of tools that I've only used once)
But, don't do it because of time or cost. The 3 pieces of galvanized pipe cost under $10, are available in any hardware store that handles plumbing supplies, and are assembled in 30 seconds.
Good luck.
Old Dec 19, 2009 | 10:14 AM
1975StroppeBaja
True. But you did suggest that using the home made tool makes it more likely to damage the seal which I don't think is true.
Old Dec 19, 2009 | 04:27 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Good luck.
What about the time for the grinding it down?
Old Dec 19, 2009 | 10:24 PM
ironmine's Avatar
ironmine
Only seconds for that, too.
I know that at least one person on this forum actually turned the flange on a lathe, but my son and I just quickly put it to the bench grinder to make it fit. Its been used 6 times now.
Good luck.
Just my 2 cents.
Old Dec 20, 2009 | 04:01 PM
tacoma9830's Avatar
tacoma9830
I found mine for 39.00 didnt seem like a bad price considering i can probably sale it for the same when im done with it.
Ford Vacuum Seal Installer for 1998 & Newer Fords:eBay Motors (item 380179111326 end time Nov-23-09 16:58:27 PST)
Old Dec 21, 2009 | 02:25 PM
tawells01's Avatar
tawells01
Good luck.
Just my 2 cents.
I was looking at a write-up that called for grinding a floor flange down to 3 3/16" not the 3 7/8" describe earlier in this thread. I guess I am just slow, because I can't grind a 4 inch diameter floor flange to 3 3/16" in seconds and keep it circular with the center whole exactly in the middle. Oh, and I would have needed it to be perfect. My failing. Actually, I would have probably ended up turning a piece aluminum or steel on the lathe and duplicating the tool I bought. I spend way to much time perfecting these kind of thing. Moreover, the actual tool controls where the seal seats, avoiding the possibility of damaging the seal. This was stated on the writeup I used which was written by someone who made the tool with galvanized pipe etc. I weighed this into my decision. A damaged seal would mean another day lost and as I said before would practically pay for the tool. That is why I decided it wasn't worth my time.
Buying the tool was cheaper than paying someone to seat them for me. I checked, they wanted to charge for an hours worth of labor. Same thing for pressing the ball joints in.
By the way, it turns out the diameter of the OTC tool that fits in the seal is closer to 3 13/16" never even checked that before. So that writeup I was using probably had a typo (3 3/16" instead of 3 13/16", closer to the 3 7/8" stated earlier in the thread). I didn't have the seals yet when I considered making or ordering the tool so I didn't measure it.
I also thought about selling the tool after I used it. Decided instead to take another track. Loan it out locally (listed on craigslist). Done this once already. Got this idea from Checker (paid a deposit for a ball joint press, used it, returned it, entire deposit was refunded). So, I take a deposit to cover the cost of the tool and refund it when it is returned.
CrowneVic
Jan 15, 2013 10:41 PM
CrowneVic
Jan 13, 2013 08:31 PM
68GTFastback
Apr 6, 2007 08:18 AM
Mexray
1978 - 1996 Big Bronco
Mar 29, 2002 09:36 AM
