95 power problem
Old Dec 18, 2009 | 05:57 PM
HrdDrv's Avatar
HrdDrv
I've checked around, but no dice on the straps. I'm sure they can be had from the dealer, or made from scratch with some braid-strap and end connectors. If I hear more, I will let you know. (If the lights aren't dimming, or dim, just concentrate on the battery ground to block, the straps are ok, just not for the battery path to ground.) Plus, all the other items grounding to the frame/chassis causes interferance. I'd put ground to block, and let all the other stuff go, so the starter gets clean strong juice. (And the alternator has strong charging path.)
Brett At TheList
Apr 18, 2012 08:03 AM
TruckBoatTruck
Dec 16, 2011 09:27 PM
fantomas
Jun 28, 2009 07:43 PM
lattices2
1978 - 1996 Big Bronco
Aug 26, 2005 08:56 AM
Beasty-Fella
Nov 11, 2003 06:49 PM
