Identify this transmission
Old Dec 15, 2009 | 09:14 AM
dhobdey1's Avatar
dhobdey1
a guy has this tranny for sale, He doesn't know what it came out of, but thinks it is in good shape, My syncro is going out into 3rd gear and needs replaced cause it grinds if you shift it too fast, I have a 1975 F250 4X4 4 speed, trans code "A", He wants $200.00 for it, Will it fit in my truck?
what tranny is this? picture by dhobdey1 - Photobucket
Old Dec 15, 2009 | 09:56 AM
Recoil's Avatar
Recoil
NP-435 due to the aluminum top.
I would say it would fit, that is what is in my 76 F-150 4x4 with an FE block.
Old Dec 15, 2009 | 10:14 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Even if it was a T-18 it would bolt on, by looking at that picture and assuming you have a factory highboy, that tranny looks like it's made for a mated transfer case setup, but you should be able to switch your output shafts if it's the same tranny.
Old Dec 15, 2009 | 10:32 AM
c.l.nye's Avatar
c.l.nye
that tranny is a ford NP435 from a 2WD. it is missing the rear tail shaft cover. You can tell by the speedo gead and threaded end of out put shaft. should work in your HB as it should have a divorced T case.
dhobdey1
Sep 7, 2010 04:02 PM
dhobdey1
Jul 30, 2010 01:52 PM
dhobdey1
Dec 28, 2009 01:15 PM
dhobdey1
29
Dec 22, 2009 11:48 AM
dhobdey1
Dec 9, 2009 09:29 AM
