duraspark on a points distributer?
Old Sep 6, 2010 | 11:45 AM
dhobdey1's Avatar
dhobdey1
I just transplanted a 1971 460 into my 1975 3/4 ton highboy, 4x4, 4 speed. My original wiring has a duraspark box on the inner fender, there is three electrical connectors (plug-in style) by the firewall, these I unplugged my original 360 from when I removed it, The new 460 has a points sysytem, I want to start my truck, can I just take any switched 12 volt to the new coil? if thats all I did would it run? should I get rid of the duraspark box? Thanks, Dan
Old Sep 6, 2010 | 07:00 PM
Dialtone's Avatar
Dialtone
It should start and run with a switched 12 to the coil, but you need an ignition resistor in the path to keep it from eating the points faster than normal.
One option might be to replace the points with a pertronix system. I think you can get rid of the resistor with those systems, but read up on it first.
Question, what advantage do you see by NOT running the original duraspark system on this motor??
OOPS: I did not catch that the original engine was a 360...my bad.
Old Sep 7, 2010 | 01:49 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The condenser is there to keep the points from arcing.
A resistor will keep the coil from overheating...
Edit: I really like the DuraSparkII system, and would keep it way over going to points.
That's a nice, clean and relatively stock looking motor you have there.
Old Sep 7, 2010 | 08:20 AM
dhobdey1's Avatar
dhobdey1
well, if I keep the duraspark, I think I'd have to replace the distributer, is this correct? is this the only thing I'd have to do? I like the idea of going to pertronix.
Old Sep 7, 2010 | 08:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, you'd need a Duraspark distributor and possibly a new coil bracket to clear the larger distributor cap.
Here's a pic of my (buried in emissions) 460.
<a href="http://www.flickr.com/photos/24183730@N03/2340583825/" title="IMG_1929 by Jim_Urrata, on Flickr"><img src="http://farm4.static.flickr.com/3094/2340583825_c27cb60fc7.jpg" width="500" height="375" alt="IMG_1929" /></a>
The Pertronix system might be right for you but I like the fact that no matter where I am there's an autoparts or junkyard that has this DSII stuff on the shelf.
Old Sep 7, 2010 | 09:15 AM
dhobdey1's Avatar
dhobdey1
thank you so much for your help, I'm gonna look for a duraspark 460 distributer
Old Sep 7, 2010 | 11:52 AM
daveengelson's Avatar
daveengelson
It's basically the same distributor; exchanged the 65 w/ 390 points for electronic dizzy at local Napa auto parts, seem to recall not costing more than $45-$50. Not sure if nec. but went with the larger cap, which requires the adapter, wow is the cap expensive.
Old Sep 7, 2010 | 02:38 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave,
The cap is bigger in circumference to put more space between terminals.
The more powerful DSII system will arc and track like crazy if you try to use the smaller cap.
That shallow cap is $11.99 at my local Napa.
Old Sep 7, 2010 | 03:50 PM
daveengelson
Originally Posted by ArdWrknTrk
Dave,
Jim; appreciate the information!! Thought it best to go with the 9mm plug wires so consequently ended up with the large cap. Replaced the cap less than 2 weeks ago and it came to $29 plus some change. It's bout the 3rd cap replaced over past 15k and been sticking with the blue ignition component ensemble; wow, considering the difference in price, think I can live with the grey cap.
Old Sep 7, 2010 | 04:02 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I run the Napa Belden premium wires, they're 8mm I think.
Seem to last forever.
Rulebreaker
Electrical Systems/Wiring
32
Sep 25, 2016 12:24 PM
dhobdey1
30
Jan 7, 2011 04:48 AM
dhobdey1
Jul 30, 2010 01:52 PM
79F-1504x4
May 28, 2010 09:39 PM
dhobdey1
Dec 9, 2009 09:29 AM
