Sponsored by: Real Truck
Air bag code
Old Dec 15, 2009 | 12:09 AM
krejci.mike's Avatar
krejci.mike
Air bag code
My air bag light has been on for a while. It will blink a few times then go solid, from what I've heard the number of blinks tells you the code. I get a 32 or 33, anyone know what these mean and what I should check?
Thanks,
-Mike
Old Dec 15, 2009 | 01:19 PM
cartmanea's Avatar
cartmanea
32=Driver Side Air Bag Circuit High Resistance or Open
33=Passenger Side Air Bag Circuit High Resistance or Open
Find out which one it is, then go from there. If driver's side it could be wire chaffing in the steering column, seems to happen occasionally. If passenger side, possibly a problem with the passenger deactivation switch, if you have one. I've heard if the bulb goes out in them it causes a code, new switch is spendy so most disassemble it and replace the light.
Old Dec 15, 2009 | 04:53 PM
krejci.mike
Thanks. I'll look into it a little more
Old Dec 15, 2009 | 11:05 PM
EXv10's Avatar
EXv10
I had air bag codes on my Ford van for a long time and then I had a free check done on it before I sold it and I talked him into turng the code light off.........................sold it!.
