last night the cord got riped off my stock block heater and i was wondering how to rewire it
as in what one is the ground the positive and the negitive
//// the wire looks like that
Originally Posted by 9473
If you strip the outside back a bit you'll see the insulation of the three. Ground will be a different color, mine was green. The other two were the same.
I'm assuming by your try at a picture that the cord is flat with 3 parts. Ground should be the middle, the other two don't matter, one is hot, the other neutral, but like a light bulb, block heaters don't care which is which. If you have a multi-meter test for continuity across the outer two wires, which would prove those are hot and neutral. The middle should NOT have continuity to either of the outside wires.
