burnin oil!
Old Dec 12, 2009 | 11:02 PM
wreckinball's Avatar
wreckinball
burnin oil!
well i found the issue and it is surprising. The smoke i have been seeing is coming from the CDR. it may as well have been a direct tube to the oil pan. Somehow i had overfilled by a quart or so. Dead cold it was above the max fill line. I just drained the whole deal and painstakingly added new fresh oil till i hit halfway on the crosshatch. I cleaned out the cdr and it works fine like usual. I had been seeing abouttwo to three drips of oil under the bellhousing but that i think is my mysterious fuel leak that is intermittent. Sometimes three or so drops other times not at all. It is thin and dries with a ring like it was mostly fuel. Probably washing off the rear of the engine after i had that nasty bout with a front crank seal. Made a mess. After i had gotten the oil to level, i fired it up and it smoked for a second then went away. Under high rev it would blast a mist but not like it used to. When going to work, it is dark and the lights of the car behind me were showing me i had issues. It looked like a james bond car smoke trick hahaha. In the day it was noticeable at takeoff but not any other time unless i had it floored. I am making a run to town tomorrow so we shall see if cleaning it all out and having a proper level makes a diff! haha. I am also getting some DK or seafoam and running the fuel filter wash again. That helped last time but the oil came right back so no fix. In the mean time......
Twilight Fenrir
Nov 5, 2013 05:21 AM
maverick1701
28
Mar 18, 2012 12:43 PM
mikecwik
Oct 19, 2010 08:13 AM
bl311
Aug 20, 2007 11:44 PM
slspokane
Mar 29, 2007 11:41 PM
