Transmission ID
Old May 19, 2000 | 02:39 PM
carmello's Avatar
carmello
Transmission ID
My grandfather has somewhere between a 1969-1972
ford F-350. It's two wheel drive and it has a 360
for a motor. I wanted to pull the four speed out
of it and put it in my 1979 ford F-100. My truck has a 300 straight six with a 3 on the tree. I wanted to know wether the four speed was a New Process or I was told it could be a Berge Warner, I don't know if I have the name right. I also wanted to know which one is better out of the two and can I use the bell housing from the 3 speed for the four speed. Please help if you can.
~Joe~
Old May 19, 2000 | 03:10 PM
StockMan's Avatar
StockMan
Transmission ID
[FONT COLOR="#0000ff" SIZE="+1" FACE="Veranda"]I have been told that the bolt pattern is the same between the 3 and 4 speed manual truck trannies. I have never verified this personally. But if so, the tranny should swap in without incident. As far as determining whether the 4 spd you have is NP435 or T-18--I have a tranny id section on my web site. Go to the Technical page off the main page. I hope this helps.[/FONT][BR]
http://members.aol.com/tbeeee/page/flareside.jpg[BR]
[FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="-2" FACE="Tahoma"]
1967 F-250 FE 390 4wd LWB Styleside
1966 F-250 I6 240 2wd LWB Flareside
http://www.hometown.aol.com/tbeeee
Old May 19, 2000 | 11:59 PM
Trail_Rider's Avatar
Trail_Rider
Transmission ID
Old May 20, 2000 | 12:03 AM
Trail_Rider
Transmission ID
Having done this swap - 3 spd to 4 spd - it's a bolt in swap. The only thing I had to do was "adjust" the carrier bearing mount about an inch with a torch and a BFH.
Trail Rider
Old May 20, 2000 | 08:32 AM
carmello's Avatar
carmello
Transmission ID
Thanks when I go to my grandfathers I won't have to worry about getting a bell housing and I'll know what kind of transmission it has. Thanks.
~Joe~
Jafo56
Sep 29, 2014 08:53 PM
heavyb38
Oct 14, 2010 03:47 AM
Joe Rodriguez
1947 and Older Ford Trucks
Oct 14, 2004 04:31 PM
BEAVER
Nov 17, 2002 05:24 PM
TheFonz
Jul 30, 2000 10:24 AM
